Hardwood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 01:32 PM   #1
hardwood flooring
When installing 3" engineered hardwood straight. When starting in the first room and laying the planks what is the best way to make sure you are square in the next room when continueing laying the hardwood?
homeboy is offline   Reply With Quote
Old 09-14-2011, 08:46 AM   #2
Never too old to learn
Dudester60's Avatar
Could you be more specific ? I'm not sure I understand the question.
Dudester60 is offline   Reply With Quote
Old 09-14-2011, 09:25 AM   #3
Experienced
Jackofall1's Avatar
Hello homeboy and welcome to the best DIY'r site on the web.
There is a simple answer to that question if I understand it correctly, it called planning.
Be aware that walls in a house are not parrallel and square with each other (at least 99% of the time) so planning, laying the floor out, running string lines helps ensure the straightness of the floor which in most cases will deviate from the walls.
Mark
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 02:19 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
