Old 06-17-2011, 10:45 AM   #1
Hardwood Flooring
How is the quarter round cut to install at door, straight cut or angle cut? If angle what degree?
Plumberswife60 is offline   Reply With Quote
Old 09-11-2011, 11:27 AM   #2
Never too old to learn
Dudester60's Avatar
Hardwood Flooring
I usually cut the quarter round at an angle when I come to a door or opening, (45 degree on both sides of the door)
Dudester60 is offline   Reply With Quote
Old 09-11-2011, 11:49 PM   #3
firehawkmph's Avatar
Hardwood Flooring
I cut on an angle too. I usually don't carry the angle all the way to the point of the corner. I leave a small flat equal to how much the door casing sticks out past the base. That way the angle should finish just about at the outer edge of your casing.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
DYI Project - Hardwood Flooring Install in Hall and Bedrooms godmaster Flooring 9 04-26-2009 10:22 PM
