Hardwood Floor On Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 11:44 AM   #1
Hardwood Floor on walls
I saw this while staying overnight at a hotel. Anyone have any tips to give me as i would like to do this in my condo. I think it would look great in between my patio door and window. The opening is approx 2 ft x 9 feet high. I have left over bamboo from my floor. How do i achieve this look. The dept and size of the strips are all different.
Any ideas on how i do this.
laflsyl10 is offline   Reply With Quote
Old 02-25-2013, 11:50 AM   #2
Rewards Points: 12,830
Cover wall with at least 1/2 plywood and I'd use my narrow crown staple gun to attach the flooring to the wall.
http://www.ridgid.com/Tools/R150FSA-...r/EN/index.htm
Old 02-25-2013, 01:01 PM   #3
Thanks for the reply.
How do I achieve the difference in thickness and depth in the wood. Would I just rip the hardwood in different thickness. From the picture, the boards are approx 1 inch in thickness.
Old 02-25-2013, 01:30 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
I've seen this before where each of the slats are stained/painted in slightly different colors too. Really makes for an intricate looking piece. Do you know that the thicknesses are actually different? You could achieve the same look by just offsetting the front faces and gluing them together. Of course, the back wouldn't be flush, but if you put it in a thick frame, nobody would ever know.
The other easy option would be to get a board, say 3/4" thick, and start ripping different thicknesses out of it. Turn cut each board on its side, and you would have a uniform set of 3/4" slats, with varying thickness.
hyunelan2 is offline   Reply With Quote
Old 02-25-2013, 03:22 PM   #5
"You can do anything"-Mom
brockmiera's Avatar
It looks like they did a base layer all the same height and then came in after and doubled up the slats randomly.
brockmiera is offline   Reply With Quote
Old 02-25-2013, 03:23 PM   #6
brockmiera's Avatar
I turned your pic for you.
Old 02-25-2013, 04:29 PM   #7
Newbie Bill
Rewards Points: 518
I like the look of that, now that it is turned the right way. My wife would lament on the dust collection issues.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-25-2013, 05:50 PM   #8
If you installed them horizontal then they could just be attached to the studs.
Old 02-25-2013, 09:03 PM   #9
Rewards Points: 264
I might suggest using an unfinished wood and then planing the boards to different thicknesses to help get the textured look. Or BR-111 I believe makes flooring for walls, so maybe check out their site. The area you need is so small that you could probably find someone on craigslist or something that has a leftover bundle of a cool exotic wood or something. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Old 02-26-2013, 01:48 PM   #10
Rewards Points: 150
That looks like BR-111 Corduory.
zakany is offline   Reply With Quote
Old 03-11-2013, 12:25 PM   #11
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
yes looks very nice, here we do this too, actually it is just waste, small pieces of wood that are considered as waste in our production and with a process called fingerjoint, you glue all the small pieces together to a bigger piece. Good for recovery results.
harrymontana is offline   Reply With Quote
Rain seepage stain removal and sealing on bare block walls Peipei9 Concrete, Stone & Masonry 2 03-29-2012 06:37 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
