Hardwood Floor Vs. Dog - Flooring - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 09:15 AM   #1
Rewards Points: 89
new house, 2yrs old, hardwood floor in foyer/hallway. While the dog gets groomed and nails trimmed regularly, I was noticing scratches on the wood. In hopes of protecting the wood, I used an Acrylic finish from OrangeGlo to protect the floor (squeeze on...mop...dry). So now the acrylic top coat works to protect the wood from the dogs nails, however, while the wood is not being scratched, the acrylic finish is being marked by his nails....long whitish streaks....ugh. I guess if I put another coat down this would cover the marks....for a few weeks at least.
Any ideas on how to resolve this? any easy way to remove the marks, and keep my floor protected? (no....getting rid of the dog is not an option)
mahjohn is offline   Reply With Quote
Old 04-17-2010, 03:11 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 232
How about socks?
Large dogs and wood floors are always a problem. If it's not the scratches, it's the water dish spills and drooling if the water is kept on the floor.
Gotta live with it along with the pet hair, spotted lawn and other clean up chores.
Jaz
Old 04-22-2010, 04:37 PM   #3
One option is to cover the hardwood with a floor covering that isn't permanent like an inexpensive laminate. The laminate will perform better with the dog and when you're ready you can remove it and live on the hardwood again.
Hardwood floors are soft but tend to develop character that suits the home over time. Either way, if the dog stays the hardwood won't look the same
rcuerrier is offline   Reply With Quote
Old 04-22-2010, 06:25 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Dog1.........hardwood 0
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-23-2010, 02:56 PM   #5
Rewards Points: 264
Just over 1 year ago we installed unfinisished red oak floors and finsished them on site with 4 coats of oil based Poly-urethene.
At the time we had 2 full grown Old English sheepdogs. In November they had puppies. 11 PUPPIES.
The floors are holding up awesome. clean up couldnt be easier with the smooth poly-finish. One advantage, was that we sanded and finsished on site so it is SMOOOOOOTH. Prefinsished floors have a micro bevel between each and every board. this makes room for dirt debris to get trapped and cause scratching just my opinion.
What have I done is offline   Reply With Quote
Old 10-18-2013, 12:50 PM   #6
Water Based or Poly
Which one should be used??? I am getting opinions from both ends...
chinacat01 is offline   Reply With Quote
Old 10-18-2013, 12:52 PM   #7
Should I use Poly or water based finish??? Opinions vary...
Old 10-19-2013, 11:26 AM   #8
Have you though about installing a handscraped or distressed floor? These come screwed up from the factory. If the dog scratches them, you wont notice it because the differing textures don't reflect the light back straight at you -- kinda breaks it up and makes it less noticeable.
Something like this: http://weshipfloors.com/flooring/elm...5-hand-scraped
clayduster71 is offline   Reply With Quote
Old 10-19-2013, 08:07 PM   #9
Rewards Points: 3,362
It would be cheaper to refinish the floors with poly than replace the floor.
Canarywood1 is online now   Reply With Quote
Old 10-21-2013, 02:15 PM   #10
I've been advised against using OrangeGlo because it leaves a residue on your floor that is difficult to remove and hard to recoat over, as modern polyurethanes will not bond to it.
As for the dog toenail scratch issue, scratches in finish can be covered with more finish, but scratches in wood will have to be sanded out. You have several options, including using a tougher finish or putting down more rugs, even. I'm not the expert in this area, but I've found Pete's Hardwood Floors' website to be particularly helpful in answering all my questions about hardwood flooring issues (with some spunk and sass). This is an article relating to pets and hardwood floors: http://www.peteshardwoodfloors.com/W...od-floors.html.
brookeellen is offline   Reply With Quote
Old 10-22-2013, 10:31 AM   #11
If you go with a good prefinished floor finished with an aluminum oxide UV coating, it will be much harder for the pet nails to scratch the coating. The UV cured aluminum oxide finish is many times harder than anything you can coat your floors with on site.
Add this to going with a harder species with a hand scraped texture and you have a winning pet combination. Hand-scrapes are already scratched up when you buy them - so your dog is just adding value to your floors!
Just my 2 cents worth
Discount Hardwood Floors!
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 01:45 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
