Old 03-29-2007, 10:58 AM   #1
hardwood floor vs ceramic tile vs puppy
I am in the process of laying down flooring for my foyer and kitchen; I also have a small puppy who is prone to "leaks", most oof which are caught w/in 15 minutes, bec we don't let her roam the house unattended.
My question: which affords greater protection from these leaks; an oak flooring which has been sanded/coated w/ polyurethane, or ceramic tile which has been sealed?
Burat is offline   Reply With Quote
Old 03-29-2007, 11:32 AM   #2
Darylh's Avatar
Tile, Tile Tile
Darylh is offline   Reply With Quote
Old 03-29-2007, 11:50 AM   #3
Tell me how you really feel!
Old 03-29-2007, 01:00 PM   #4
Answering your question with one of my own. Which do you find more often in a bathroom?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-29-2007, 02:16 PM   #5
yummy mummy's Avatar
Go with tile. I have hardwood throughout my home and I would never leave water or any spill on them for 15 minutes. Not even 15 seconds.
Hardwood is very nice, but can be delicate. If you drop anything on it, more often than not it will create a dent.
If you have a puppy, I would definitely go with tile.
yummy mummy is offline   Reply With Quote
Old 03-29-2007, 04:12 PM   #6
Home Improvement Guy
ron schenker's Avatar
Tile...as long as it's done properly
ron schenker is offline   Reply With Quote
Old 03-30-2007, 10:43 AM   #7
Please elaborate on proper installation.
Also, is there any kind of tile which cannot be properly sealed? The kind we're interested in are those w/ the rustic, textured look (Mediterranean look).
Old 03-30-2007, 10:59 AM   #8
Tiling is really simple as long as you follow the steps all the way.
1. lay backerboard (cement board) down where you are tiling
2. Apply thinset (concrete that tile adheres to tile)
3. Stick the tile down making sure that each tile is aligned
Obviously it goes into more detail than that. You can go to a quick workshop at a tile store or Home Depot or Lowes and get detailed info.
Like any DIY project take your time and do things right. If you want more info, just ask I we can give you the right direction.
cibula11 is offline   Reply With Quote
Old 03-30-2007, 01:17 PM   #9
Lightbulb
WOOD>>>Is the best of all for beauty, and you should put tons of sealer and polyurethane coats over it, .....But, consider the part of the country you live in as well.
Tile is much more sturdy, and with a mosaic....you can't go wrong.
Sure wood is beautiful, but if you plan to live in the house with pets, or kids or high traffic...Tile would be much sturdier..(and you can use throw rugs, as well) to warm the floors up in winter,..Aaaand then theres Pergo or laminate flooring.. ...ulk! fake looking wood, but supposedly sturdy.
If you do go with Tile, ask for assistance,for the right size spacers, the larger the spacer the more grout, ..a darker grout is also easier to maintain...but seal the grout as well....this will kepp it cleaner longer.
Make sure you have a lot of glue on the floor, and press firmly down on each tile as to form a suction between the floor and tile, otherwise you will have a hollow in between, the floor and the tile and you will hear it every time you walk over it
Also make certain you have lots of paper towels, waterpails..(inexpensive will do), large sponges and dishwashing, rubber gloves are important, to protect you hands, You need to clean-up as you work (as best you can). If you don't you will never get the grout off the floor, and your life will become diy hell.. .hahah....Anyway, the glue is not as bad, but all in all, Clean as you work!! Or you'll regret it, and one more thing is make sure your floor is level before you start....or forget it! I do have tile floors, But my name ain't Woodpecker for nuthin!
Woodpecker is offline   Reply With Quote
Old 03-30-2007, 01:27 PM   #10
I would say tile or wood, if the wood is not prefinished. If it's prefinished, then the pee can get in between the seams. The grout for the tile can absorb some of the pee also, if it's not sealed. I think newly finished wood may be the best bet, especially since you can get to any accidents as quick as you say you can.
handy man88 is offline   Reply With Quote
Old 03-30-2007, 09:05 PM   #11
Talking
Just how long do you expect the puppie, to pee?
Ya, ever hear about wee wee pads and training?
Old 03-30-2007, 10:21 PM   #12
Super Moderator
Floorwizard's Avatar
Good point.
But the correct answer is definately tile.
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 03-31-2007, 04:56 PM   #13
JUST COMMON SENSE, TEE HEE
More On This Topic
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment I am going to be showing you how to do a dry run with your tile to make sure the layout is working. As you can see we have snapped our lines and what you can do if... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
