Hardwood Floor Splintering - Flooring - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 08:56 AM   #1
Hardwood floor splintering
I'm in the process of sanding and refinishing the floors in my house and its been going great until early yesterday. The wood in one or two of the rooms is splintering and destroying the sanding pads. I've done some searching on the internets and haven't seen much that was helpful. The wood in question is original to the house (1920) and I believe is Long Leaf Pine.
What might be causing the splintering and is there any way to deal with it other than replacing the wood or carpeting over it (NOT my first choice.)
(images uploading to imageshack - i'll edit once they are up)
cellophane is offline   Reply With Quote
Old 01-29-2010, 06:45 PM   #2
what kind of sander are you using?
just tile is offline   Reply With Quote
Old 01-29-2010, 10:16 PM   #3
have a drum sander and a disc sander. paper grit ranges from 20ish to 150 or so.
Old 01-31-2010, 01:10 PM   #4
has the wood gotten wet. if so you may not be able to sand real well. becareful where it is splintering. maybe try a belt sander or hand sand it in that area. good luck.
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
