Hardwood Floor Sanding Grits? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 04:11 PM   #1
hardwood floor sanding grits?
in the next two weeks I will be refinishing the hardwood floor in my 1980's home it has aprox 700 sq ft of hardwood in it. I will be renting a drum sander to do the job of sanding, the only thing I am not sure about is the grits of paper I should use as well has how much of each I will prob need. Thank you and I will be posting pictures when done, as I have noticed no one has done after asking for help.
handyman_squire is offline   Reply With Quote
Old 08-20-2012, 10:12 PM   #2
Too Short? Cut it Again!
What grits and how much is going to depend on what type of hardwood you have, the amount of finish to be removed, and how deep into it you are going to have to go when you sand. Can you provide a bit more information?
Also, have you used a drum sander before? Doable but they are big machines and can get away from you in a hurry. The orbital floor sanders are more forgiving.
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
