Hardwood Floor Rotting - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 08:55 AM   #1
I have what I believe is engineered hardwood in my entryway. The first row of planks next to my entry way have rotted out. The threshold for the door was completely rotted as well. My entry door is surrounded by brick and upon closer inspection had zero silicone around it. I have since sealed it with silicone.
I have gone into the crawl space and pulled back the insulation to examine the subfloor in that area. I saw a little evidence of moisture but it did not appear there was damage.
Could water come in where the exterior casing was not sealed gotten caught between the flashing and the flooring causing the hardwood flooring to rot without damaging the subfloor?
krombie19 is offline   Reply With Quote
Old 07-14-2011, 10:02 AM   #2
It seems likely that if the visible flooring rotted, the subfloor rotted too; if nothing else because of simple proximity (one bad apple...). But I think you'll discover the answer when you take out the engineered wood!
Minich is offline   Reply With Quote
Old 07-14-2011, 10:47 AM   #3
AGWhitehouse's Avatar
Have you inspected the sweep (weatherstripping on bottom) on your door? It may be possible you have seepage through there during rains. over time the floor stays wet enough to rot out. Don't need alot of water to deteriorate it.
AGWhitehouse is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
