Old 03-18-2008, 02:17 PM   #1
Hardwood Floor restoration...door jam gaps
We recentely tore out carpeting and we decided to restore the hardwood floors beneath. The problem we have now is that the existing door jams, which were installed on top of the carpeting we tore out, now leave a gap above the hardwood floors. What is a solution to this problem, without removing the door and lowering it to fit snuggly on top of the floor? The gap is from a 1/2 to an 1".
helgymatt is offline   Reply With Quote
Old 03-18-2008, 02:40 PM   #2
Here are a couple photos...
Notice the doors are also high too....are these obscenely high?
Old 03-18-2008, 04:21 PM   #3
Tileguy
Bud Cline's Avatar
You're screwed!!!
Old 03-18-2008, 06:18 PM   #4
Yep, I think your right! We just tore out the doors and are looking to get new ones.
Old 03-18-2008, 10:41 PM   #5
lol is that your professional opinion?
mike costello is offline   Reply With Quote
Old 03-18-2008, 11:14 PM   #6
Tileguy
Bud Cline's Avatar
Mike "YES" that is my professional opinion! There are just some situations that don't require a lot of conversation and explanation. This is one of those. There's nothing more to say!
Old 03-19-2008, 05:58 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No other solution but to move the door frame down, if it can go down.
Remove the casing. Cut the nails holding the door frame. Allow the frame to drop to the floor. Square/level/plumb - the door frame, and re-install.
Re-attach casing. Patch walls if needed.
By the looks of it, you may still have some concrete visible even after that....(?)
Good Luck.
- Build Well -
Old 03-19-2008, 02:41 PM   #8
Tileguy
Bud Cline's Avatar
May be asking for trouble...looks like plaster walls to me. Then there's the 37 coats of paint at the top of the door casing that will be exposed in the form of a ridge.
Old 03-22-2008, 04:21 PM   #9
I am just a novice but you could cut some filler pieces to fill the void and then finish it out with base shoe moulding and that would cover most of it. Not an perfect fix but would look much better than what you have now at least do all the wall base boards and maybe a little caulk and it would hide most of it ! what do you have to loose ? but other than that you got to cut out the jams and cut down the doors .
MWHITLEY is offline   Reply With Quote
Old 03-22-2008, 08:37 PM   #10
Tileguy
Bud Cline's Avatar
Old 03-23-2008, 09:03 PM   #11
Wood Flooring & Carpentry
lawndart's Avatar
You made a wise descision. Is that a Pine floor your looking to re-finish?
lawndart is offline   Reply With Quote
Old 03-24-2008, 03:57 PM   #12
Tileguy
Bud Cline's Avatar
Looks to me like it has already been refinished.
Easy maintanence and child friendly Hardwood floors? gante Flooring 2 03-11-2008 09:04 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
How to tell what hardwood... evane Flooring 9 09-06-2007 02:42 PM
