Hardwood Floor Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 09:27 AM   #1
Hardwood floor questions
Am I able to put radiant heating under a hardwood floor?
Also, if I'm installing unfinished hardwood in a kitchen with many cut outs and inserts which will cause many face nails to be used would it be worth it to just full trowel fill te entire floor?
mmostek4 is offline   Reply With Quote
Old 02-17-2013, 10:31 AM   #2
Civil Engineer
Rewards Points: 4,562
When we installed our electric radiant heat in the kitchen, the manufacturer indicated that it was safe to use under hardwood flooring. We planned on a stone floor, so that was OK also. If you plan to nail in the hardwood, you need to be extremely careful that you do not nail through the electric floor heat, that would be most unfortunate. This can likely be avoided by using short enough nails that they do not penetrate the subfloor, however if you use an electric or pneumatic nailer, it is possible that a few of the nails are overdriven, in which case the tip of the nail might poke through the subfloor. You may want to consider hand nailing the floor to avoid this unfortunate possibility.
Daniel Holzman is online now   Reply With Quote
Old 02-17-2013, 10:43 AM   #3
Rewards Points: 13,256
What type of heat is it going to be?
Electric, forced hot water?
Old 02-17-2013, 10:55 AM   #4
Was planning on electric but nothing is set in stone yet.
Old 02-18-2013, 12:35 PM   #5
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Yes, use Zmesh radiant under your hardwood and you can nail through it anywhere you want. It's low voltage, even slow growth heat so it won't create hot spots that can warp the wood.
http://www.comfortradiant.com/zmeshinterior.php
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 01:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
