Hardwood Floor Over Slab On Grade Concrete? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 08:12 AM   #16
Rewards Points: 13,456
Engineered and laminite are totaly differant, and even look totaly differant.
Your never going to see an ad for a home boosting about having new laminte floors.
Old 12-07-2012, 10:03 AM   #17
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Originally Posted by ToolSeeker View Post
Ok the difference between hardwood and engineered floor is hardwood is the species of wood all the way thru the plank, engineered is basically plywood (no movement- expansion or contraction) with whatever species of wood you want on top so you could match. Hardwood can be refinished quite a few times, engineered can only be refinished about 3 times, if this is important to you. The decision is yours I'm just trying to give you another option. There are some flooring guys on here that may do better at explaining this than I did, they should be along to help.
You did a good job explaining it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ToolSeeker (12-07-2012)
Old 12-08-2012, 12:08 AM   #18
Rewards Points: 264
Originally Posted by gwilkrrs View Post
ok- i feel better to investigate and explore engineered with that explanation- i lumped all flooring into 2 catagories real wood floor and fake floating floors- i do not like the laminate (wood)flooring and have installed a couple for others. this sounds like wood onj wood wich wouldnt have the dreaded click sound when walking on
Many engineered floors can have as thick of a top layer as real solid hardwood. So it can be refinished just as many times. A couple good brands to check out are real hardwood floors and shamrock. You can find both online. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
ToolSeeker (12-08-2012)
Hardwood Over Concrete Slab iplay1515 Flooring 17 10-07-2012 09:08 AM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 05:54 AM
Below Grade vapour barrier on concrete below engineered hardwood.... PTO Flooring 2 07-17-2011 10:23 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 06:16 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
