Old 10-12-2012, 12:58 PM   #1
Hardwood floor over current hardwood
I am planning on redoing my entire 2nd floor hardwood over hardwood. How do you handle the top step? What is the best way to trim off door jams?
brauchbob is offline   Reply With Quote
Old 10-12-2012, 03:44 PM   #2
if you do that your steps will no longer meet code, plus you will have to cut all your door jams higher. years from now when all that flooring is removed the jambs will be 1-1/2 or more above the floor. if you have to trim the doors also then those would need replaced also or be 2-3 inches above the floor. nailing to hardwood that moves when it expands and contracts is just asking for trouble. if you want to do it twice then just nail over the existing.
Old 10-12-2012, 06:42 PM   #3
Why? What's so wrong with what's there that can not be refinished?
And the other poster is 100% correct, more trouble then it's worth to just add another layer.
Which direction to lay hardwood Dudester60 Flooring 3 09-11-2011 10:12 AM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
