Hardwood Floor Makes Popping Sound - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 02:00 PM   #1
Hardwood floor makes popping sound
Hi,
In two sections of our house the hard wood floors make a popping sound when you step in the area then step out of it. I'm assuming either the hardwoods aren't installed correctly , the subfloor isn't down good enough or there is something in the basement that is maybe rubbing or making the sound when we step in the area then leave the area.
Any ideas ?
jbessboro is offline   Reply With Quote
Old 01-25-2010, 08:22 PM   #2
If there is access from below, have someone walk around above while you listen, look, and feel for the movement from below.
Once you find the movement, figure out a way to eliminate it. This will probably involve screws driven from below, with extreme care as to the length of the screw.
Could be that you just need to re-fasten the hardwood to the subfloor. Could be that the subfloor is loos from one of the joists. In either case, a properly placed, proper length screw will work.
And you may need your partner to stand on the loose spot while you re-fasten it.
YesMaam27577 is offline   Reply With Quote
Old 01-25-2010, 08:52 PM   #3
is the floor nailed or glued down?
just tile is offline   Reply With Quote
Old 01-25-2010, 09:31 PM   #4
It's nailed down.
What type of screws would I use ?
Old 01-25-2010, 09:35 PM   #5
you need to find the source of the poping. you may have loose nail . but till you know why it pops you can't find a fix. let us know what you find and we'll try to help. good luck.
Old 01-26-2010, 10:52 AM   #6
Originally Posted by jbessboro View Post
It's nailed down.
I'd use a self-drilling wood screw. Don't use drywall screws, as they are way to brittle for use in wood floors.
Popping sound (loud) in hot water tank andrewd80 Plumbing 2 12-25-2009 06:38 PM
Popping Sound Vandiyan Home Theater 10 08-29-2008 12:52 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
Hot Water Heater with popping sound handy man88 Plumbing 4 10-19-2007 02:37 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
