Hardwood Floor Installation On 2nd Floor - Underlayment Necessary? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 04:02 PM   #1
Hardwood floor installation on 2nd floor - underlayment necessary?
I will be installing hardwood floors on the second story of my house. I was wondering if I need to use some sort of underlayment or if I should nail the wood directly to the plywood subfloor. I'm guessing there is no need for a moisture barrier, but I thought there might be some other reason (such as sound dampening) that might require the use of some sort of underlayment between the hardwood and plywood.
Thanks,
J.
digexpressions is offline   Reply With Quote
Old 11-30-2007, 08:16 AM   #2
Rewards Points: 1,088
Thanks,
J.
Yes, you generally put down resin paper or tar paper. Tar paper has more sound dampening qualities.
handy man88 is offline   Reply With Quote
Old 11-30-2007, 11:15 AM   #3
Knows some but not all
Thanks,
J.
I would think having a sound deadening underlayment would be a nice thing to have, if you don't like the clop, clop sounds of shoed feet ringing from above. There are many underlayments that are available for sound damening purposes and some are almost as thick as a carpet padding! I'd google on "sound dapmening underlayment" or "sound deadening underlayment" and I'm positive you'll get more hits than you can stand and you'll find a product that will work for you.
However, if you and your family are not bothered by the foot step sounds, adding the underlayment will only help minimize squeaks, if you put something down that isn't meant to absorb sound.
Just my 2 cents worth.
J.
SewerUrchin1 is offline   Reply With Quote
How to tell what hardwood... evane Flooring 9 09-06-2007 02:42 PM
old termite damaged hardwood Kbotard Flooring 8 05-14-2007 03:22 PM
New Hardwood and Toe Kick yogibayer Flooring 2 03-19-2007 09:22 AM
