Hardwood Floor ID And Install Question - Flooring - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 11:00 AM   #1
Hardwood Floor ID and install question
Hi all,
I am wondering if anyone knows what this floor is. It's in our living room and I want to extend it into our bedroom (currently carpeted). The house was built in 93 and is located in Conifer, Colorado.
Also, I'm wondering if anyone has suggestions about install. I'm debating about doing it myself - my one fear is leveling the floor. I installed laminate flooring in an old kitchen and the floor wasn't quite level and we had squeaks. I don't want that top happen here... is it difficult to determine levelness and should I just have it installed by a pro?
Thank you!
Hardwood Floor ID and install question-lr_floor_1.jpg   Hardwood Floor ID and install question-lr_floor_2.jpg
gtono is offline   Reply With Quote
Old 05-27-2011, 05:43 PM   #2
DIY staff
Rewards Points: 7,174
Red Oak---Cabin grade--(not select)--sanded in place
If you install it your self--find any squeaks in the subfloor and add screws to stop the squeaks.
Often hiring the sanding and finishing part of the job is not to expensive.---The install is not difficult for a person of moderate woodworking skills.
Old 05-27-2011, 06:58 PM   #3
thank you!
Thanks for the confidence boost I needed to put me over the edge to do it on my own. I've done a lot of home remodeling and repairing, so this sounds like a good one to add into my aresenal.
Also, thanks for the id of the wood.
Old 05-27-2011, 07:13 PM   #4
DIY staff
The pneumatic floor nailers make the job easy--Compared to the old hammer driven ones I used to use.
They can be rented by the day----I recently purchased a Harbor Freight on for $55--Final mark down from $179--Laid 650 square foot with it and it worked well.
Old 05-27-2011, 07:20 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can probably rent a floor nailer and compressor in Littleton. Home Depots, Lowes, Ace Hardware usually have them for rent. Or most any tool-rental outfit.
XXX
Old 05-27-2011, 09:38 PM   #6
More help always welcome
Thanks! Is the nailer run by a compressor? When I was a teenager I helped my dad install a floor and we just whacked the top of the nailer. I have a mid-size compressor and thought I would rent the nailer, good to know I can do it at a somewhat local store.
Always great to get more info, thanks so much.
Old 05-27-2011, 10:34 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The newer models are "air-assist". You still wack'em.
XXX
VERY Quick Ceiling Fan install question! Fox Electrical 11 03-23-2014 12:56 AM
Hardwood install over concrete, Garage remodel to artist studio. Augie Flooring 8 12-29-2010 09:45 PM
culture stone install question raven27 Building & Construction 4 11-02-2009 10:31 AM
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 10:00 AM
Laminate Selection & Install Question sdcards Flooring 1 10-13-2005 04:12 PM
