Hardwood Floor Finish - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 08:11 AM   #1
Rewards Points: 27
Hardwood floor finish
Hi guys
I just bought a house and i am trying to figure out what is the finish of my hardwood floors (picture attached). There are very fine scratches and I need to know what kind of finish it is in order to use the right products to maintain the floors.
The finish is not glossy and you can kind of feel the wood grains when you touch it. So it does no look like polyurethane. Also i put some water on the floor and no white marks (so i guess not wax as well). So maybe oil?
Thanks!!
Roger
rogerusp is offline   Reply With Quote
Old 09-01-2013, 09:04 AM   #2
Rewards Points: 13,450
White oak has a deep grain and if it was not sanded enough you still could see and feel the raised grains even after it was sealed.
Old 09-01-2013, 09:21 AM   #3
Rewards Points: 27
So what finish you think it is?
Old 09-01-2013, 10:38 AM   #4
Rewards Points: 3,520
If it's solid 3/4" it's more than likely polyurethane,if it's engineered flooring then it's probably poly and aluminum oxide.
Canarywood1 is offline   Reply With Quote
Old 09-01-2013, 01:46 PM   #5
Rewards Points: 274
It might be polyurethane.
alexjoe is offline   Reply With Quote
Old 09-01-2013, 01:46 PM   #6
K&B Designer
Live_Oak's Avatar
Satin poly.
Live_Oak is offline   Reply With Quote
Old 09-01-2013, 02:03 PM   #7
Rewards Points: 27
Thanks guys. I was questioning myself if it was polyurethane because when you touch the wood it is not as smooth as other polyurethane finishes i have seen.
Any suggestions of products to revitalize to hardwood floors?
Old 09-01-2013, 02:40 PM   #8
Then it was probably finished on site,as opposed to a factory finish.
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
