Hardwood Floor Care - Flooring - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 08:50 PM   #1
Hardwood Floor Care
Hi All,
We just had white oak hardwood floors installed with a natural finish and they are absolutely beautiful. After installation, three coats of polyurethane were applied with sanding between each coat.
How do we care for them? Do we periodically apply a wax coating or some other protective barrier? Do we periodically buff them?
Bob Guercio is offline   Reply With Quote
Old 03-01-2011, 09:37 PM   #2
Keep any product that says "wax" or "polish" or any of those rejuvinator/refresher/reinvigorater products as far from your floor as possible. They will cause nothing but problems.
Sweep your floor with a soft bristle broom or vacuum it (without the spinning beater brushes) to get the big stuff up. The more often you do that the better, as any dirt or grit on your floor turns into sandpaper when you walk on it.
Best thing to clean it with is a spray cleaner like 'Basic Coatings Squeaky Clean' or 'Bona Professional Hardwood Cleaner'. A cleaner you mist down, and then wipe over with a microfiber mop. You only want to do this when it looks like it needs it though, don't make it a regular 'once a week' type of thing... just when it needs it.
Vinegar and water is a fairly common solution as well. It works, but the spray cleaners above are safer.
Whatever you do, please don't use waxes or polishes, and don't wet mop it.
Mikef5000 is offline   Reply With Quote
Old 03-01-2011, 11:26 PM   #3
Rewards Points: 200
Floor Doc is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
help...tiling over hardwood m0nguse Flooring 0 01-06-2011 10:14 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
