Hardwood Floor Buckling - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2009, 08:54 PM   #1
Dave E's Avatar
Send a message via Skype™ to Dave E
Hardwood floor buckling
New construction. I had 3" x 3/4" quarter sawn oak installed, finished on site. Some areas have buckled upwards and you can feel it when you walk on it.
Installed on 3/4' T&G OSB (can't recall the trade name, but pricey and designed for installations that might be exposed to moisture). Hardwood acclimatized in house for 2 weeks. This was all done last spring. I think I know what probably caused it. OSB was wet (winter construction, snow etc.). I compounded it by running a propane construction heater in the basement for the better part of a month. Lots of condensation. When the rim joist insulation was going in, the installers mentioned some mold evident. I then ran a de-humidifier non stop and it would need to be emptied at least once a day. The flooring had been installed by this time (but not finished). In addition to the de-humidifier, the furnace was now running and an ERV. Does it make sence that I pulled enough moisture out of the sub-floor to shrink it, while the flooring above (isolated by resin paper) stayed the same, and had nowhere to go, so it buckled upwards. The flooring did cup to some extent, but has since returned to it's normal flat state. It does not have a v-groove, and no gaps or cracks have opened up. Quite the opposite actually. You can't see the buckling up visually, but you can sure tell when you walk on it (feels spongy and you can hear it). All of the affected areas are at the perimeter near the baseboard. None are out in the field area, so I'll live with it for now if I have to.
My question is - can anything be done about this without pulling up the affected areas and relaying new material? I was wondering if I could add weight (eg bundles of shingles for the shed I'm building) and screw into it from below. Or perhaps just drill some holes, through-bolt to pull it down, screw from the bottom, then fill the through-bolt holes with oak plugs and finish.
This is a bunglalow. About 1900 sq feet installed, maybe 35 sq ft affected. I paid a good buck to have it done "right". The finish is Minwax and not impressive from a durability standpoint. The installer and I parted ways over the poor quality of finish (debris, etc), and the fact that I think he should have picked up on the possible moisture differential issue. When we first met, it was his 40 years experience that helped us make the choice to hire him. Of course, he didn't actually do the install or finish work. In any event, it's not a case of calling him back. (Is that Mike Holmes I see coming up the walk?)
I won't lay replacement flooring myself, but screwing it down (if that'll work) is well within my technical expertise. Thanks in advance for any suggestions.
Dave
Dave E is offline   Reply With Quote
Old 03-27-2009, 06:23 AM   #2
All of the things you mentioned likely added to the problem. The house should have been dryed out(propane heaters don't dry out anything), the flooring should have sat in the room where it would be installed, opened, for 3-6 wks before being installed.
Why would you put screws thru that beautiful oak?? Get a flooring professional, not the guy that installed it, to have a look see. Maybe they can salvage it.
Old 03-27-2009, 06:44 AM   #3
ccarlisle's Avatar
Hmmm, let's see: IMO if the floorboards haven't individually 'cupped', or have resumed their flat state, then there's a humidity balance that has been reached between them and the surroundings. So OK there...now if what you call 'buckling' is a spongy feel when you walk on it, that may be a subfloor or underlayment installation issue. Not enough screws, insufficient layout overlapping, even missing paper (if any was put down), for example. You may have success reaching that with screwing from underneath, but not 100% sure about that...
But if the buckling is happening around the perimeter, I'd want to be sure there was enough room left for expansion/contraction by leaving enough gap. Is there a gap or is something in there?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-27-2009, 06:46 AM   #4
Dave E's Avatar
I was wondering if I could weight the floor down so it was flat, then screw up through the sub-floor and into the oak from underneath. Sub-floor and oak is 1 1/2', so I figure an inch and a quarter screw would keep it below the surface. I could do that easily.
Because the areas are not that big, ie. 1 1/2' x 3' (with the 3' parallel to the baseboard), I thought maybe I could lay a cleat or piece of angel iron on the affected area, drill 2 5/16 holes down through the surface, and thru-bolt to pull it down flat. With that done, I could screw up from the bottom like in the first suggestion. Remove the cleat and it should stay there. The oak is finished fairly dark, so to hide the thru-bolt holes I'd just fill them with an oak plug, stain and finish and I doubt you'd see it.
Because the affected areas are adjacent to the baseboard, I suspect the installer didn't leave enough, (or any) space between the wall plate and the flooring. If you dry the subfloor enough, can it actually shrink enough to close that gap and cause the flooring to bunch up? That's what it looks like, but that would mean the room just got narrower by a quarter to a half inch or so, and I find that hard to believe.
Old 03-27-2009, 06:57 AM   #5
Dave E's Avatar
Ccarlisle. We were typing at the same time. I'm certain it's not a subfloor issue. It's T&G, every joint tight, glued down by the framers and I personally screwed it down. And it's on open web trusses 12" deep with no span more than 13". This is definitely an issue where there's a space (picture a big bubble) between the flooring and the subfloor. To check the gap between the flooring and plate means I'll have to pull the baseboard to inspect. If there is none, is there a saw that will cut that close to the wall or is pulling up floor and replacing sections the only way to restore the gap?
Old 03-27-2009, 08:24 AM   #6
ccarlisle's Avatar
I see...is this a floating floor or was every floorboard stapled/nailed down? nailed to each other or into the subfloor OSB?
Either way but especially if a floating floor, there should be a 1/8" or 1/4" gap between the finished planks and the wall to account for the expansion of the floor due to humidity. At least that is done in tiling, but I see no reason not to do the same. If there's no gap there and the floor expands, the floor will bubble as you say. Somewhere. It won't cup but a number of the boards will "tent".
If the boards that tent are around the outside, that points to "no expansion gap" or some of the boards were nailed down in a floating floor configuration. If all the boards were nailed down, then something in the installation process seems off.
Old 03-27-2009, 02:41 PM   #7
Dave E's Avatar
Not floating. Everything nailed down. Staples I believe. Just like the pre-finished stuff from Bruce, etc. The only difference is that it's quarter sawn (rift actually) and not prefinished. I believe you're right about the "no expansion gap" part. I wasn't around for the install, but my wife says they did leave a gap, and she's sure because she wondered if the baseboard/shoe would cover it.
Anyhow, the fact that it seems to "go down" when you stand on it (you don't actually feel it go down, but you sure hear it), can you see any problem with me weighting it down and screwing up from the underside? I'm pretty sure the sub-floor and the hardwood are the same moisture content now. What I don't know is whether the two, being different material, would expand and contract the same and at the same time.
Old 03-27-2009, 03:07 PM   #8
ccarlisle's Avatar
Well, if its not floating then it must be stapled...not to each other but to the underlayment. So how come they're up? Bad staples? In any case, where the boards are not attached, that's a weak point in the floor and hence the expansion there.
By corollary, if they are attached, there's no real need for an expansion gap for the floor...only a small one for each board along two walls of the perimeter.
IMO, you should be able to screw them from underneath...
Old 03-27-2009, 10:12 PM   #9
Registered User
Rewards Points: 526
Osb got wet- insulators saw mold- rosin paper protected------- Rosin paper has a permeance of about 50----- it let the moisture right through. Semi- permeable is asphalt covered paper, a vapor retarder.
When it rains while I frame houses, I drill 1/2" holes in the sub-floor where the water pools. The perimeter of the deck gets all the extra water from the walls as well, it gets soaked. After framing, and the rough-in is done, the insulator spreads plastic vapor barrier under the crawlspace.
The oak sucked up any moisture present in the OSB, and you probably have a good crop of mold there. I saw rosin used as floor protect over wood flooring in a remodel, until it got wet from shoes and left pretty pink footprints. Be safe, GBAR
Old 03-28-2009, 09:28 AM   #10
Still Learning
... maybe 35 sq ft affected
That's a clue there. And rift sawn shouldn't move that much. Sounds like an isolated problem. Water intrusion, leaks in the wall, roof above? What's underneath?
HardwoodGuy is offline   Reply With Quote
Old 03-28-2009, 10:17 AM   #11
Civil Engineer
Rewards Points: 4,862
All wood flooring needs an expansion gap around the outside, regardless if it is rift sawn, flat sawn, or quarter sawn. See www.nofma.org/Publications/tabid/82/Default.aspx for a complete discussion of proper installation technique for wood flooring. If your floor gets wet from the top, the top of the boards expand, and the boards cup downward (convex). If the floor gets wet from below, the bottom expands, and the board cups upward (concave). Since your boards are not cupped anymore, this indicates that the wood has achieved a relatively uniform moisture content, which by the way can be checked with a moisture meter if you choose to.
Since the boards have lifted off the subfloor, this suggests an expansion issue. I have T&G oak flooring in my house, and every summer when the humidity is at a maximum, a specific area in the middle of the floor buckles upward. As in your case, you can feel it, and see it as well. Come fall, it dries out, and the buckle disappears. No cupping in either case, however there simply is not enough expansion room to handle the full width of the boards. You can check on the link above the expansion for different types of wood, and based on the relative moisture difference between maximum and minimum, you can determine the required gap.
And yes, if the gap is insufficient, there is a special type of offset blade saw that can cut immediately next to a wall, I think it is called a cabinet saw. I have never used one, but you can rent them from my local rental place. Very handy when you need to cut a groove next to existing cabinet work, such as for tile or floor installation.
Old 03-28-2009, 12:49 PM   #12
Registered User
Rewards Points: 526
Thank you, Daniel, very informative. Toe-kick saw. Be safe, GBAR
Old 05-11-2009, 09:17 PM   #13
Dave E's Avatar
Sorry guys. I started this thread and didn't get back to finish it. I think Daniel Holzman's reply is what I'm dealing with. Virtually all cupping gone. BTW, the cupping was at the joints, not in the middle of the planks. Between it being winter and my ERV going, I had the humidity down into the high teens. Way too dry. Installed a Honeywell Steam Humidifier and couldn't be happier with how I can control humidity. Back to the floor. I think the problem is no gap around the perimeter. Should I pull thebase boards and cut one. Baseboard is only primed at this point, so while I don't relish the thought, I'm prepared to do it. What I'm not sure of is whether this will permit the floor to lie flat again and prevent the noise when I walk on the (currently) affected areas. Someone said a while back that, yes, I could screw up through the subfloor from underneath. Is that a good idea? I was also wondering if it would be possible to drill some kind of hole from underneath and inject something like PL adhesive in, not really to fill the gap, but to re-fasten the flooring to the subfloor.
Dave
Old 05-11-2009, 09:21 PM   #14
Dave E's Avatar
And Daniel H. I see your on right now, but it's getting late for me and 5:00 am comes early. I'll check tomorrow to see if you get this.
Thanks again
Old 05-12-2009, 09:04 PM   #15
Hardwood floors over concrete slab....
I have hardwood floor, t&g, installed over a subfloor attached to the concrete slab. I have buckling around the exterior perimeter in two areas, and in the hall at the wall. I also had buckling in the dinning room about 3 months after installation, at perimeter. The installer came out, ripped up a section of the floor expecting to find water. None was there, then he took a reading and said too much moisture in the slab. I now believe that was not exactly true, but install tile there instead. Now I have the issues in the areas mention above. The floors look great and you can only really tell it when you walk in the areas. I suspected that the subfloor was nail down securely. They use a gun which shot the nails into the subfloor and slab. I can tell it is the subfloor that has become losse and not the hardwood.
Is there a way to repair without ripping up the floor. Can I screw from above and fill the holes and finish the areas?
Goldtor64 is offline   Reply With Quote
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
