Hardwood Or Engineered Over Crawlspace - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 11:32 PM   #1
Rewards Points: 27
Hardwood or engineered over crawlspace
I am pretty inexperienced as a DIYer, but after a previous thread decided to try installing either hardwood or engineered over a crawl space. The popular suggestion seems to be engineered because of the crawlspace? Opinions? The other question is, how will I be able to ensure the moisture level in the crawl is acceptable to not damage the flooring. Currently, only a third of the dirt ground is covered with a plastic barrier. And natural draft vent on all four sides. I have noticed seepage through the foundation wall after a lot of rain and wet dirt around the edges. Looking around , the joists and subfloor appear dry and mold/mildew free. Any suggestions or input is very much appreciated. Thanks.
jjones1020 is offline   Reply With Quote
Old 03-12-2013, 11:34 PM   #2
Rewards Points: 27
I live in the St. Louis area, if that is relevant.
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
