Old 09-30-2011, 11:27 PM   #1
hardwood door thresholds
I'm going to be laying 5/8" hardwood (bamboo) and ceramic tile on the main floor of my home. From what I have read, I should lay the hardwood perpendicular to the floor joists. This works well in one room because then I can use a piece of the flooring in the other direction for the door jam threshold.
However, there will be another room with hardwood where the door is facing a different direction. I won't be able to run a plank between the door jam for a threshold because the floor will already be running in that direction.
Would it look weird to have two rooms with different looking thresholds or should I just run the planks in both rooms into the tile (without a plank in the opposite direction) and leave a gap for color matched caulking?
Any suggestions would be greatly appreciated. Thanks!
stankholio is offline   Reply With Quote
Old 10-01-2011, 07:19 AM   #2
bubbler's Avatar
I have it running both ways in my house. One hallway runs parallel to the joists for ~13'. It's also running parallel thru my living room and dining room which is a ~27' stretch at max. This is white oak strip flooring, 60 years old in the living room/dining room, no obvious indication of where the joists are (due to sagging I assume). I've also seen it running two different directions in other houses, so it might be common enough to run it parallel?
I'd say as long as you have a solid & strong subfloor it won't be enough of an issue to matter. My subfloor is ~60 year old 1x12's nailed down perpendicular to the joists. If you are worried about yours, now is the best time to strengthen it.
But then again, I'm not a pro.
bubbler is offline   Reply With Quote
Tags
hardwood, threshold
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 10:23 PM
Installing new hardwood ontop of existing hardwood benshouse Flooring 1 11-13-2009 11:25 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
