Hardwood In Carriage Barn - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2007, 07:56 PM   #1
hardwood in carriage barn
hi all,
If I am putting down hardwood in a second floor of a carriage barn that will not be heated every day throughout a upstate NY winter; do I need to worry about the temperature change and the wood warping?
thanks!
ss3777 is offline   Reply With Quote
Old 09-23-2007, 05:03 PM   #2
Floorwizard's Avatar
Yes you will need to worry.
Not much you can do but keep the temp and humidity at a constant.
An engineered floor is more stable, but still may cause probs.
Floorwizard is offline   Reply With Quote
Old 09-24-2007, 07:09 AM   #3
RippySkippy's Avatar
I guess that depends on what look you after. If you want it to look like a well finished floor...it probably won't stay like that very long. If you're after the wood plank look that will have gaps over time, no problem, that type of floor has been in garages/barns for centuries!
RippySkippy is offline   Reply With Quote
Old 09-24-2007, 10:00 AM   #4
Rs
Good point, I think that is probably what we will go with, wide plank, rustic.
Thanks!!
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 10:58 PM
How to tell what hardwood... evane Flooring 9 09-06-2007 01:42 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
New Hardwood and Toe Kick yogibayer Flooring 2 03-19-2007 08:22 AM
