Hardwood-Carpet: Header Board Or Threshold? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 11:35 AM   #1
Rewards Points: 150
Hardwood-Carpet: header board or threshold?
I am planning a new hardwood install that will adjoin to a new carpet install in a bedroom.
Should I just rip a header board and break its edge, or use a transition piece?
The hardwood will be just a landing and open hall at the top of the stairs, so the area isn't particularly large. One doorway will be perpendicular to the boards, another parallel.
I think it would look better without a transition. However, expansion would be better accommodated with a transition. It might also eliminate running a tack strip across a doorway (would it? I dunno).
Thoughts?
zakany is offline   Reply With Quote
Hardwood to Carpet Transition Piece segal Flooring 5 12-05-2012 06:49 PM
Marble Threshold too High with concrete board amgdiy Flooring 6 02-01-2012 07:24 PM
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 03:19 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Need to carpet hardwood stairs clasek Flooring 7 04-21-2009 11:00 AM
