Old 03-24-2008, 01:53 PM   #1
Hardwood Butting to Tile
I'm in the process of installing solid hardwood flooring and would like some recommendations for the following:
I have ceramic tiles installed in the hallway with a marble threshold seperating the living room. I would like to install the hardwood in the living room, however is it ok to butt the hardwood (installed parallel) to the marble threshold or do I need to leave a 1/8" gap for possible expansion? The height of the ceramic tiles and hardwood are the same elevation.
anthony9887 is offline   Reply With Quote
Old 03-24-2008, 03:58 PM   #2
Tileguy
Bud Cline's Avatar
1/8" gap then caulk it.
Old 03-24-2008, 09:30 PM   #3
remodeling pro
Get color matched caulk from the tile supplier and it will look just like the grout.
troubleseeker is offline   Reply With Quote
Old 03-25-2008, 12:54 PM   #4
Even though I will not be needing to grout between the marble threshold and the wood. Are you saying if I butt tight up against the marble threshold, that the wood in time would expand and push those tiles?
Old 03-26-2008, 09:24 PM   #5
Tile Contractor
Bill_Vincent's Avatar
Absolutely.
"Whether you think you can, or you think you can't, You're probably right."
Bill_Vincent is offline   Reply With Quote
Old 03-27-2008, 03:44 PM   #6
This is just the info I'm looking for. We want to install 16" slate (very consistant gaged, brazilian) on point in the kitchen, entry and hall. In the living room and in the family room it will butt up to a 3/8" engeneered wood floor, 5" plank (Anderson). I was told that if I butt it to the cut ends I will have much less of an expansion issue is this true? Also, If I run a board along the cut end, a 4" board and then butt up to the tile (being set on point) will I still have many expansion issues? Lastly, I dont want to have a tile border along the edge of the tile just the on point pattern ending at the wood is this okay to do?
red shoes is offline   Reply With Quote
Old 03-27-2008, 07:41 PM   #7
Tile Contractor
Running the diagonal into the hardwood is fine, but you want to run a border piece of wood. You don't want to butt the tile up against the ends of the hardwood boards.
Old 03-27-2008, 10:57 PM   #8
Bill thanks for your reply. I noticed in the photo you had both a wood border and a tile border, but if I understand you correctly I omit the tile border:
on point tile
1/8 space to be caulked
border of wood
wood butting against border
right?
Is there anything special I have to do or worry about where the points of the tile come up to the wood border?
Old 03-27-2008, 11:06 PM   #9
Tile Contractor
Not at all. The points will have triangular shaped pieces on either side of them, so you'll end up with a straight line against the wood.
And yes, you're correct about the order.
Hardwood Butting to Tile-sportland2.jpg   Hardwood Butting to Tile-sportland3.jpg
Old 03-28-2008, 10:30 AM   #10
Hrmm, the previous owner of my house installed tile and hardwood and unstead of just getting colour-matched caulk, he put a small metal piece where the wood and tile meet. I personally don't like the look of it and might try the caulk method. It's just 2x3' lengths so it wouldn't be hard to remove one of the metal thresholds and see what's under it. There is a border of wood (like all of the pics above) on the one side where the tile meets the planks in a T, so that's good.
curls00 is offline   Reply With Quote
Getting tile the same level as my hardwood? digexpressions Flooring 5 03-31-2008 09:28 PM
heated tile but over hardwood... canadaclub Flooring 3 02-08-2008 06:26 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 06:25 PM
Hardwood Or Tile? ImFlippinCrazy Flooring 11 04-25-2007 04:56 PM
hardwood floor vs ceramic tile vs puppy Burat Flooring 12 03-31-2007 04:56 PM
