HardiePanel Siding Panels For Tile Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 08:53 AM   #1
PatrickGSR94's Avatar
Rewards Points: 87
HardiePanel siding panels for tile underlayment?
Co-worker is renovating an old house and will be doing some tile work over conventional floor framing and foundation. What is the difference between the Hardie cement board substrate products and the panel siding products? He says he can get the panel siding at a cheaper cost per SF than the backer board.
The panel siding products are slightly thicker than the 1/4" backer board products. But don't the backer board products have a rougher surface which probably helps with thinset adhesion?
The subflooring is some kind of 3/4" panel product but isn't really all that great. He was talking about putting this backer board down and then using a self-leveling compound, but I'm not sure if that's the best way to level a conventionally framed floor.
PatrickGSR94 is offline   Reply With Quote
Old 09-26-2011, 10:21 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why would he need Hardi panels AND Self Leveller?
That's a real waste of money when the Self Leveller is all that is really needed.
Replacing old siding panels giappino Building & Construction 5 11-23-2010 07:39 AM
How do I *not* mangle polyiso panels when I pull vinyl siding for insulation blow? steveel Building & Construction 5 10-10-2010 09:02 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
