Old 09-30-2012, 04:01 PM   #1
hardiebacker
We are putting tile just in the foyer of our room...we rip the carpet out and have plywood.can we tile right on the wood or do we need haediebacker
gascott538 is offline   Reply With Quote
Old 09-30-2012, 07:28 PM   #2
JetSwet's Avatar
hardiebacker
Yes you need cement board, but you also need 1" of ply from joists up 3/4" won't do it. Do you know what you have for joist size and spacing?
JetSwet is offline   Reply With Quote
Old 09-30-2012, 10:32 PM   #3
Tileguy
JazMan's Avatar
hardiebacker
I agree with our friend from NY about the backerboard, (or membrane), but although the more the better, there is no requirement by any manufacturer or tile association that says you need 1" of plywood. Matter of fact all say 3/4" ply or OSB is plenty and many say even 5/8" ply is good enough on 16" oc joists and properly installed of course as in all cases.
I do not like a single 5/8" ply, but 3/4" I've done hundreds of times and as noted more than meets standards.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
ToolSeeker (10-02-2012)
So blasted confused about hardiebacker and vapor barriers ajtool Kitchen & Bath Remodeling 7 12-16-2010 09:43 PM
Hardiebacker/ Floor Tiling question.......remaking the "BOMB SHELTER!" Dyoung Building & Construction 5 03-20-2010 10:09 AM
Hardiebacker.... vapor barrier TAR ? Dyoung Building & Construction 1 02-26-2010 08:37 PM
Hardiebacker tub surround shaggyb Kitchen & Bath Remodeling 15 02-16-2010 08:07 PM
Hardiebacker over tile? el_goodo Flooring 9 02-16-2009 09:06 AM
