Hardiebacker - Flooring - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 07:14 AM   #1
Hardiebacker
Hi,
I have a chipboard base in my kitchen (not a solid floor) and want to tile the floor. Should I use Hardiebacker first and then tile onto it?
Hannah170180 is offline   Reply With Quote
Old 07-28-2012, 07:41 AM   #2
DIY staff
Rewards Points: 7,174
Tell us more---How thick is this 'chip board'?
Could ir be OSB? Oriented strand board?
Also--what are the floor joist ? How big--how long from foundation to beam?
If the floor itself checks out as okay for tile--then yes---a tile backer 1/4"" set in thinset and nailed or screwed is needed.
I prefer Wonder board or Durrock myself---I don't like to use Hardibacker.
Old 07-28-2012, 11:06 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
What Mike said.
The first thing you need to do is find out if your floor is suitable for tile. The big concern is deflection (AKA bounce).
If you put down tile on a floor that is too bouncy you risk cracked grout, loose tiles, and a general mess.
As Mike said, knowing the size and span of your joists is the first step, along with finding out exactly how your sub-floor is constructed. If you have a floor vent, pulling the cover off is often a good way to get a peek at your sub-floor.
So blasted confused about hardiebacker and vapor barriers ajtool Kitchen & Bath Remodeling 7 12-16-2010 09:43 PM
Hardiebacker/ Floor Tiling question.......remaking the "BOMB SHELTER!" Dyoung Building & Construction 5 03-20-2010 10:09 AM
Hardiebacker.... vapor barrier TAR ? Dyoung Building & Construction 1 02-26-2010 08:37 PM
laying hardiebacker over osb moegumble Flooring 2 08-06-2009 06:05 AM
Hardiebacker over tile? el_goodo Flooring 9 02-16-2009 09:06 AM
