Hardie Board For Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 12:16 PM   #1
hardie board for floors
I have installed hardie board prior to tiling a bathroom floor. Manufacturers instr. say to make the screws flush - however many do stick up a little, but a lot less than the thickness of the thinset I will be applying (1/4"). I would say the screws that are not flush or lower are protrudung no more than the thickness of a wallboard blade. Do I have to unscres and reapply the non-flush ones?
npeswillie is offline   Reply With Quote
Old 03-10-2012, 12:43 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Willie,
1st question, what is under the Hardie and did you spread thin set underneath as you installed the boards?
Sometimes just backing the screws out a little then forward again does the trick. Otherwise roofing nails work like a charm.
The thin set spread with a 1/4" trowel, (might not be big enough, but I don't know the type or size of the tiles) may be 3/16" high, when tiles are set into it, max thickness 3/32". So the floor need to be flat.
Jaz
Old 03-11-2012, 10:28 AM   #3
Thanks Jaz: When you said roofing nails would work, I only re-screwed the worst ones. It seems to me that most of the screws were not sticking up any further than the nail heads would be.
By the way, I did not use thin-set putting the hardie board down. The subfloor was solid and level. The Hardie rep said that it was not necessary when floor was solid and level - this info is thru the tiling expert at my local Lowes. Time will tell if hs is full of it. Thanks again.
Old 03-11-2012, 11:30 AM   #4
Rewards Points: 528
He must not read his companies instructions for laying it down. he is incorrect. Please, before you go any further, go back and do this.
framer52 is offline   Reply With Quote
Old 03-11-2012, 12:34 PM   #5
Rewards Points: 13,732
The thin set under the tile board is to fill any small low spots between the floor joist. Without it the tile board will flex and the tiles may crack.
Sometimes I counter sink the screw holes with a 1/2 masonery drill bit so the screws will set flat to the surface.
Old 03-11-2012, 06:04 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
Willie, you said...............
By the way, I did not use thin-set putting the hardie board down. The subfloor was solid and level. The Hardie rep said that it was not necessary when floor was solid and level - this info is thru the tiling expert at my local Lowes.() Time will tell if hs is full of it.
FYI, there are no experts at Lowes. Applying thin set under all backer boards is critical for a good long lasting floor tile installation. You should stop and do it right.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
framer52 (03-11-2012)
Old 03-11-2012, 06:37 PM   #7
Rewards Points: 528
And for the second time in this thread, do what the Jazzman says, it is critical...
Do not assume the people worjking at lowes are close to being correct.
Around here, it is failed contractors that work at the big box stores.
Old 03-11-2012, 07:23 PM   #8
Ironlight's Avatar
... the tiling expert at my local Lowes.
This is an oxymoron. While there may in fact be the occasional expert at one of the big box stores, they are few and far between. Just because they are lurking in a given aisle and present themselves as experts does not mean a thing.
Think about it. Why would a tile guy work retail at Lowes when he can make more than twice as much actually laying tile for a living?
Ironlight is offline   Reply With Quote
Old 03-11-2012, 10:49 PM   #9
Rewards Points: 340
maybe his knees hurt and he is tired of being underbid by young whippersnappers
kt82 is offline   Reply With Quote
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-17-2012 11:46 PM
GMP075-3, Bad Board?? RaySuave HVAC 2 12-12-2011 10:02 AM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
installing hardie backer board alamojo42 Flooring 2 10-25-2009 08:21 PM
Hardie Board Vs.....? tattood General DIY Discussions 2 08-10-2005 09:26 PM
