Old 08-05-2009, 12:41 PM   #1
hardibacker under cabinet overhang
Hello, I am installing, well at least attempting to install a ceramic tile floor in my kitchen, I am putting hardibacker over the subflooring but I have a problem, The kitchen cabinets overhang the floor about 4 inches and I don't know how to put any screws under the overhang. I thought of putting the screws in on an angle but it is hard enough to sink the screws flush. Any ideas?
LuLu is offline   Reply With Quote
Old 08-05-2009, 11:45 PM   #2
toolbelt Tina's Avatar
i don't know the height of this attachment but...
http://www.harborfreight.com/cpi/cta...emnumber=91767
or try a nail gun under the toe kick. The angle of the gun should fit under the over hang
good luck
toolbelt Tina is offline   Reply With Quote
Old 08-06-2009, 01:31 AM   #3
Tileguy
JazMan's Avatar
So what's the problem? You nail or screw the board right to the edge of the toe-kick. Open the doors so you can get a bit closer. Don't forget the thin set mortar under the Hardie.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 08-06-2009, 05:58 PM   #4
Tileguy
Bud Cline's Avatar
Be sure all of your Hardi panels are of a sufficient size so that you don't have to put a fastener under a toe-kick. Do as Jaz suggested. Use modified thinset and you'll be fine.
Old 08-07-2009, 03:25 AM   #5
Follow the advice of Bud and Jaz. They are gods in my book!
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 12:59 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
tight overhang clearance on gable abutment - how to cover...? rtoni Roofing 7 10-12-2007 12:13 AM
