Hardibacker Thickness For Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 06:52 PM   #1
Rewards Points: 1,062
Question
Hardibacker thickness for bathroom floor
should i use 1/4 or 1/2" Hardibacker for my bathroom floor? the beams underneath are 2x10 and the subfloor is 3/4" tongue-and-groove OSB. i plan to use 12x12, 3/8" thick marble tiles.
thanks
Old 11-15-2011, 08:55 PM   #2
DIY staff
Rewards Points: 7,174
Marble will need a very stiff floor---the 3/4" osb is not stiff enough--adding 1/2" BC plywood will be needed---then 1/4" cement board set in thinset and nailed or screwed.
These 2x10 floor joists---what is the unsupported length?--( from foundation to beam or from outside wall to bearing wall if it's a second floor)
amakarevic (11-16-2011)
Old 11-15-2011, 09:23 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
Mike is absolutely right, you need more strength between the joists. Probably won't meet minimums for joists' deflection either. Let us know what the span is along with species and grade if you can find that info stamped on the joists.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 11-15-2011, 11:19 PM   #4
Question
i doubt the beams will be sagging because they are only 12 ft long and there are two load bearing walls on the floor under perpendicular to them (powder room - load bearing wall - hallway - load bearing wall - utility alcove).
having said that do you think the existing 3/4 OSB + maybe 1/2" DUROCK maybe will do? i heard durock is stronger than hardibecker (although i like hardibecker cause it seems easier to cut).
besides, if i did what you suggested, it would be so much higher than outside the bathroom (carpet on top of subfloor) that it would look awkward, kind of like half a step up almost ... LOL
Old 11-16-2011, 04:40 AM   #5
DIY staff
Backer board adds no strength what so ever--so 1/4" is plenty.
OSB is weak and flexible--add plywood on top or live with cracked stone.
If your joists are 2x12 and the spacing is 16"---and the span is 12 feet---it's a chancy install for stone.
Your deflection is 558-----stone requires 720 and tile 360----good floor but not great,
Old 11-16-2011, 01:19 PM   #6
so for the 1/2" additional subfloor support on top of the normal 3/4" OSB subfloor, should i use OSB or plywood?
also, since it will be a big jump up when you get in the bathroom, what do you recommend for the threshhold divider, considering it is marble tile inside?
thanks
Old 11-16-2011, 01:21 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Use "underlayment grade" plywood (Exposure 1).
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 11-16-2011, 01:33 PM   #8
Question
thanks, Bud. one more question: for the walls, does that require 1/2" cement board?
Old 11-16-2011, 01:36 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Always 1/2" on wall studs, never anything less.
Old 11-16-2011, 02:44 PM   #10
what is everyone's favorite cement board brand? hardibacker or durock?
Old 11-16-2011, 05:22 PM   #11
DIY staff
They are both a fine product---I prefer Durrock or Wonder board --but only because that is what I learned many years ago and have never had a failure--
Many installers use mostly Hardi---personal choice--
Old 11-18-2011, 03:00 PM   #12
is this a good kind?
thanks
Old 11-18-2011, 03:29 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 412
No, that is sheathing not underlayment. Go down the aisle a little further and you will find it.
http://www.lowes.com/pd_12227-99999-...7C1&facetInfo=
Jaz
amakarevic (11-18-2011)
Old 11-18-2011, 07:43 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What you are looking for should be labeled "underlayment". It will also be "exterior grade". It will also be called "Exposure 1". It will also likely be "B-C". Unfortunately nomenclature varies around the country but "sheathing" definitely is not what you want.
Old 11-19-2011, 05:25 AM   #15
DIY staff
If plywood were clothing----
Sheathing is like a shirt---it's worn on the sides of a house---to be covered by siding---
Underlayment is like shoes----tough and strong and won't fall apart if you step in a puddle.
For tile---look for BC exposure 1-
The letters mean the quality of the faces--
A-smooth sanded-no voids
b-smooth voids are filled
c-rough small voids allowed
d-nasty--open knots and large voids are allowed
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 06:49 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
