Hardibacker On A Bed Of Thinset? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 05:35 PM   #1
Rewards Points: 1,062
Question
hardibacker on a bed of thinset?
i was told, on a separate thread, that if i am to tile over 1/4" hardibacker i need to set it on a bed of thinset. is this correct?
thanks
Old 04-12-2011, 05:38 PM   #2
Concrete & Masonry
Rewards Points: 636
You really should be setting all tile backer board, regardless of thickness, on a layer of thinset.
jomama45 is offline   Reply With Quote
Old 04-12-2011, 05:41 PM   #3
you mean thinset over OSB subfloor?
Old 04-12-2011, 06:05 PM   #4
Concrete & Masonry
Rewards Points: 636
Subfloor, then thinset, then tile board & anchorment, followed by the tile bedding thinset & tile, and lastly grout.
The Following User Says Thank You to jomama45 For This Useful Post:
amakarevic (04-12-2011)
Old 04-12-2011, 06:19 PM   #5
DIY staff
Rewards Points: 7,174
It's done to avoid hollow spots under the backer board.
Hardi board is very springy---it will bridge low spots --that's why the thinset--
No thinset and the Hardi will flex when you step on it and will break the tile.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
amakarevic (04-12-2011), m1951mm (08-25-2011), ttr13r (08-25-2011)
Old 06-11-2011, 10:14 AM   #6
Is there a correct thickness to the thinset between the wood and the cement board ?
I hear different requirements ? Is there a firm standard ?
Dennis
DENNIS R is offline   Reply With Quote
Old 06-11-2011, 12:02 PM   #7
DIY staff
I think Jaz answered that in your other thread---
Old 06-11-2011, 12:09 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dennis this is your third thread you have asked the same questions in. You won't get any straight answers if you don't keep things all together in a single thread. Your questions so far have been answered appropriately in two other threads.
XXX
Old 06-11-2011, 02:02 PM   #9
Sorry for any mix ups. My first go around...will try and keep it streamlined...
Thanks,
Dennis
Old 08-24-2011, 11:35 PM   #10
This is my first post so be gentle with me - I just laid one hardibacker sheet in the bathroom (which is very small - 6' x 7' with a neo-angle shower) and secured it with screws and used the thinset underneath, and it is getting late and I wondered if I laid the rest of the floor before 2 AM is it safe to walk on it in the next 4-6 hours to use the shower in the morning, or should I wait to do the rest when there would be more down time in between?
chuckt55 is offline   Reply With Quote
Old 08-25-2011, 06:36 AM   #11
DIY staff
You can get on the backer board right away---no waiting time needed.
ttr13r (08-25-2011)
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
uneven seams with hardibacker after thinset and screws wpeckler Tiling, ceramics, marble 0 03-03-2011 01:25 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
