Hard Wood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 11-26-2009, 10:03 PM   #1
Rewards Points: 125
hard wood floors
We have hard wood floors that I stained and sealed with 2 layers of polyurethane. The result is that in some places it is smooth and glass like. But in other places I can see ridges from the paint brush strokes. What happened that I got ridges and what can I do now to fix it?
debd is offline   Reply With Quote
Old 11-27-2009, 07:45 AM   #2
You're overworking your finish. Poly is self leveling & should be applied thick on level flat surfaces.
What to do now? Lightly sand the rough areas with a drywall screen, or 120-150 grit paper. vacuum & tack clean with a rag liberally dampened with mineral spirits & recoat with a heavy coat of finish. If you have access to a lambs wool applicator, you'll get better results than with a brush. 1 other tip, thin your top coat of finish with about 10-15% of naptha & it'll flow out baby butt smooth.
pinwheel45 is offline   Reply With Quote
Old 11-27-2009, 10:39 AM   #3
Rewards Points: 125
Thanks for the info. I thought I was sunk. Is there a limit as to how many layers I can put on?
Old 11-27-2009, 04:28 PM   #4
Yes, but it's not till you get to at least 5 that you need to be concerned. Even then, it's not call for a lot of concern. Get it to thick & it becomes brittle rather than flexible.
Old 11-29-2009, 01:17 PM   #5
Hand sand entire area with 120-150 grit screen with the grain of the wood. Then tack floor with a towel that has been soaked with water and rung out tightly to remove as much water as possible. Put towel on floor and put push broom on top of towel then pull front of towel over broom. Tack floor by pushing towel/broom combo over floor, flipping towel occasionally to create clean towel to tack floor and ensure dust free surface. With a brush, coat the perimeter of the floor with an even coat of polyurethane then coat the largre area of the floor with a roller/handle combination using a mohair cover or a 1/4" nap cover. The roller method is the best way to apply oil base polyurethane.(Note: In my humble opinion I would not use any Duraseal products as it bubbles and shows lap lines using this method.
addvance is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Ceramic Tile that looks like Hard Wood floor Rhonda H. Flooring 31 08-15-2012 04:53 PM
Wood floors gapping gpj111 Flooring 25 09-19-2010 09:48 AM
Furniture on wood floors antonyg Interior Decorating 2 11-28-2008 10:28 AM
Giving wood floors a new finish MystiLatte Flooring 1 04-20-2008 05:53 PM
