| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Choosing Sandpaper Grits for Refinishing Wood Furniture
by Expert Village
Okay! Now that we know a little bit about the sanders, we need to talk about going through the grits. What I mean by this is that we are going to progressively go from a courser sandpaper to a finer sandpaper throughout the process. The grit refers to... Read More »
How to Use Sandpaper Grits With a Power Sander
by Expert Village
I'm Rob McManhon with Expert Village. Sand paper is graded by the grits. The grit is the roughness, the size of the size of the roughness of the paper. Now that can be any where from a 30 grit which is very coarse to 800 grit and up for fine polishing... Read More »
Corrosion Resistant Bicycle: Parts
by Expert Village
Charles McMahon for Expert Village. We are talking about how bicycles are put together and the materials. If you want more information you an look at a college level text book, on merionmedia.com. Obviously you are using a bike out of doors in all... Read More »
Applying White Toner for Airbrushed Wood Grain Effect
by Expert Village
Hi this is Aaron on behalf of Expert Village we are going to get ready to throw down the white base and then the orange on top of it and then we are going to heat set it. I'm just putting the white base around the edges where there is going to be masking... Read More »
How to Select Furniture Making Plans
by eHow.com
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
