Hallway Floor Direction - Flooring - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 08:13 AM   #1
Hi everyone, thank you for your advice.
we are laying 3/4 inch birch hardwood upstairs.
i understand that it is best to lay it perpendicular to the floor joist.
this is not an issue in the three bedrooms.
the concern......the hallway....
if i lay it perpendicular (as in the bedrooms)......
1. where it intersects the stair nose it will be at right angles (not a huge deal)
but...
2. if you come up the stairs you will be looking at the floor lines head on, so it will look like a runway.
is it okay to do it like in this very rough and not to scale diagram?
Drakestar is offline   Reply With Quote
Old 11-30-2009, 09:25 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
The most common way would be to run it 'runway' style.
I think it'd make the hallway look weird the other way.
DM
Old 11-30-2009, 10:16 AM   #3
thanks for the reply.
we were thinking by laying it across the hall would make the hall look wider and get rid of the runway effect. i see how the runway would perhaps be the easiest since we can just continue the floor on regardless of where the direction changes in the doorways.
Old 11-30-2009, 10:30 AM   #4
the Musigician
yup, i think the hallway would look.... idunno... 'shorter and squatter' with them laid that way.
*attempting to picture it in my mind*
room to hall threshholds will be easier as well. (assuming T&G)
DM
Old 11-30-2009, 10:33 AM   #5
the Musigician
a mirror or two on the hallway walls will do wonders to 'enlarge' it as well.
Po)
DM
Old 11-30-2009, 01:34 PM   #6
Smile
Po)
DM
we've got a couple or mirrors on the wall as well, not really trying to visually enlarge, just trying to avoid that runway effect when you come up the stairs.
hopefully some others will pipe in thier thoughts as well. thanks.
Old 12-01-2009, 10:46 AM   #7
Licensed Engineer
Rewards Points: 171
Runway style.......
You may want to do the hallway first, keeping the floor lines parallel to the walls (which are probably slightly crooked), then extend the floor into the bedrooms.
The hall is the only room where any angular irregularities between floor and walls will be immediately apparent, and the only space which is too narrow to allow for adjustment.
MI-Roger is offline   Reply With Quote
Old 12-02-2009, 12:27 PM   #8
Just ran my laminate floors across the hall opposite of the hardwood under it, and it looks strange. I did it this way for a number of reasons that I won't go in to now but I was using 5" planks and it does look strange. However after living with it for a couple weeks I am over it. It was a good way to use up all the little peices left over from the larger rooms as my hall was at the end of them not between them like yours.
covelle is offline   Reply With Quote
Old 12-02-2009, 01:04 PM   #9
the Musigician
covelle: does it make the hallway look 'shorter'? that's what i imagined....
DM
Old 12-02-2009, 01:23 PM   #10
I am not sure I could say exactly why it looks strange but yeah I think it does look short. I think also it is exagerated by the 5" planks where a 3" or 2-3/4" wouldn't be as bad. It also looks strange to have so many short peices of flooring together, with the seams all being within a foot of each other. I didn't like the look of no seams in the middle and in trying to keep at least most of the pieces over 12" long you end up with about a 14" section down the middle of the hall where all the seams fall. so If I could have, I would not have done it this way.
redecorating a large wide 1950's bungalow hallway HOLLYROSE Interior Decorating 1 12-01-2009 01:14 AM
Laminating 2 rooms + hallway without transitions Arkanoid Flooring 1 08-01-2008 06:21 PM
Recess in Hallway redman08 Electrical 1 07-21-2008 06:15 PM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 08:29 PM
narrow hallway txbostont Building & Construction 1 11-01-2007 05:17 PM
