Hallway To Bedroom Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 12:51 PM   #1
Rewards Points: 137
Hallway to bedroom transition
We just bought a house that has tile in the hallway and rug in all bedrooms. I am about to put a 1/2 inch engineered wood floor in the hallway. It turns out the hallway has an extra 3/4 plywood sub floor.
I guess the extra 3/4 subfloor evened out the tile in the hallway with the rug in the bedrooms. The wood floor will now be much lower then the tile hallway.
Do I need to install 3/4 plywood in the bedroom? I would like to avoid doing that if possible. Would it be wrong to just put in a saddle? Any other ideas?
Troy32 is offline   Reply With Quote
Old 08-20-2013, 10:24 PM   #2
Sound like u need to add ply to the bedroom or remove it from the hallway.
Godspede619 is offline   Reply With Quote
Old 08-21-2013, 10:47 AM   #3
Rewards Points: 137
Yeah. I put a layer of 3/4 in the bedroom and laid the floor already. I was pressed for time and did not want to put another layer down but wanted to do it right.
No power too lighting in Master bedroom, hallway and bathroom(also fan) wackyned Electrical 15 11-09-2012 10:19 AM
Tight Bedroom and Hallway Suggestions in existing 80's basement derzer Insulation 0 10-19-2012 08:33 AM
Allure flooring transition between hallway, bedrooms, and bath? amtrak23 Flooring 3 09-23-2012 05:30 PM
My latest project is to relocate a small scuttle hatch from a bedroom to the hallway allthumbsdiy Building & Construction 7 09-03-2012 01:22 PM
How to make the transition from hallway to bedroom. Dudester60 Flooring 19 07-30-2011 09:46 PM
