Hall's Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 06:06 AM   #1
Thumbs down
A new installation of Halls Vinyl Flooring has become discoloured, bright yellow, within days of a mat being placed on it. Previous vinyl floor never marked after 4 years use..with same mats....
Can anyone offer advice on HOW TO CLEAN / REMOVE the staining...
creiners is offline   Reply With Quote
Old 07-12-2011, 08:24 AM   #2
Rewards Points: 1,520
I think this is permanent; evidently due to:
"What is antioxidant staining in vinyl floors?
Armstrong's vinyl floors have been formulated to be very stain resistant to most reagents and traffic. Certain compounds added to rubber can discolor a vinyl floor when in contact with it. These chemical compounds, referred to as antioxidants, are formulated into rubber materials to extend the life of the rubber and prevent brittleness. Some antioxidants react chemically with ingredients (plasticizers) in flexible vinyl to produce a yellowish stain. This is referred to in the vinyl industry as "antioxidant staining." Any source of rubber containing these antioxidants in contact with the floor could produce this staining. Certain types of rubber mats, rubber-backed rugs, and rubber wheels on carts, can cause this discoloration. To avoid this problem, insure that the mats and wheels which will be in contact with the vinyl floor are of the "non-staining" type of rubber."
You might call your flooring's mfg to see if they've a suggestion.
bob22 is offline   Reply With Quote
Old 07-12-2011, 09:38 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Flooring inspectors call this "plasticizer migration". Always permanent. Most companies tell you not to put a mat on their vinyl. Violates the warranty.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Tags
stains. , vinyl flooring
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 01:39 PM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 02:59 PM
No glue vinyl flooring in a wide room? BizeeB Flooring 1 11-23-2010 09:50 AM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
