#1 |
Hairline crack on basment concrete patch job
I'm redoing my bathroom in the basement, while demoing the tile on the floor which was bonded really well to the concrete underneath i broke sections of the concrete. After everything was done i patched it back with quikcrete sandtopping mix and all was fine. I let it dry and cured before walking on it but after a few days of walking over the area that was patch i notice some hair line cracks. The hairline cracks are only in the section i patched and the rest of the floor thru out the basement in fine. Im planning to retile the floor is this gonna be a big issue? If so any recommendation of what to do before i tile? Any advice would be appreciated.
#2 |
If your patch job is stuck it should be okay. You might dig at it a little and see what happens. When you say tile are you referring to ceramic tile? I would want it smoother if it is Vinyl tile.
#3 |
i havent decided which tile i want to use yet. any suggestions?
#4 |
Tileguy
If ceramic...not to worry.
#5 |
How about porcelain or marble?
#6 |
Tileguy
Porcelain - no problem.
Don't know about marble. I doubt you have anything to worry about, those cracks have nothing to do with the structural aspects of the home.
| Display Modes | |
| travertine flooring on concrete subfloor | robismyname | Flooring | 2 | 09-17-2010 09:12 PM |
| Sleeve options for plumbing through concrete? | Bruce L | Plumbing | 6 | 06-14-2008 10:38 AM |
| Concrete patch for lally column footing? | AllGoNoShow | Building & Construction | 6 | 10-21-2006 09:16 PM |
| stone veneer formula | tom1st | Landscaping & Lawn Care | 1 | 07-08-2006 05:48 PM |
| Need to expand existing concrete pad for A/C unit | miketegra | Building & Construction | 2 | 07-03-2005 11:27 PM |
