Old 08-23-2012, 07:26 PM   #1
Sycamore Inn's Avatar
Grouting Tile After Baseboards
Hi,
I put tile in the downstairs of my home. After the tile was installed I then had a contractor install the baseboards. I now have a gaps between the tile and the baseboards, where there is no grout, because the tile contractor did not take any pride in his work.
Home remodeling is not my forte, how do I now fill in the spaces with grout? I have never worked with grouting.
Thanks,
Sycamore inn
Sycamore Inn is offline   Reply With Quote
Old 08-23-2012, 08:05 PM   #2
Super Moderator
First and sometimes the hardest part--get the same grout.
Mask off the base boards----mix grout to a mustard like consistency----pack the gaps using a margin float or your fingers---
let it set up for 15 minutes---wipe with a grout sponge that is wrung out almost dry-----wait another 15 minutes and wipe again--
that's it----
If you have ever wiped up muddy foot prints,you can do this.
Old 08-23-2012, 08:34 PM   #3
Thanks Mike I have the grout and I will give it my best shot.
Old 08-23-2012, 08:41 PM   #4
Super Moderator
You will do fine--keep the sponge wrung almost dry---lift and roll the sponge as you wipe---much like you would if wiping up spilled jelly on the floor----Good luck and have fun.
Old 08-23-2012, 08:51 PM   #5
Framing Contractor
You may need to install a shoe molding. It is common practice on tile floors. This will hide about 1/2" and will also eliminate any gaps between the base and the floor.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
oh'mike (08-23-2012)
Old 08-24-2012, 10:45 AM   #6
That shoe molding is a nice finished look. Maybe someday but right now that would require too much labor because all of the baseboards would have to be done. Thanks for the suggestion
Old 08-24-2012, 01:55 PM   #7
Tileguy
JazMan's Avatar
I don't understand why you think the carpenter messed up if there's a gap between the tile you installed and the base molding he installed. The tile is not close enough to the wall if it was planned to not also install shoe molding. (which is normal with any hard floor covering).
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 08-24-2012, 09:13 PM   #8
firehawkmph's Avatar
You could also fill the grout voids with a cake decorator type of bag. Sold at tile supply houses. It would save a lot of mess and allow you to put a little dab of grout just where you need it. Also, how bout posting a few pics so we can see what you're dealing with.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Grouting Fireplace Tile Question roxksears Building & Construction 4 11-29-2009 08:21 PM
Grouting Pitted Tile mahjohn Remodeling 2 06-10-2008 04:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
