-   -   Grouting Tile After Baseboards (http://www.diychatroom.com/f5/grouting-tile-after-baseboards-154625/)
Sycamore Inn 08-23-2012 07:26 PM
Hi,
I put tile in the downstairs of my home. After the tile was installed I then had a contractor install the baseboards. I now have a gaps between the tile and the baseboards, where there is no grout, because the tile contractor did not take any pride in his work.
Home remodeling is not my forte, how do I now fill in the spaces with grout? I have never worked with grouting.
Thanks,
Sycamore inn
oh'mike 08-23-2012 08:05 PM
First and sometimes the hardest part--get the same grout.
Mask off the base boards----mix grout to a mustard like consistency----pack the gaps using a margin float or your fingers---
let it set up for 15 minutes---wipe with a grout sponge that is wrung out almost dry-----wait another 15 minutes and wipe again--
that's it----
If you have ever wiped up muddy foot prints,you can do this.
Sycamore Inn 08-23-2012 08:34 PM
Thanks Mike :) I have the grout and I will give it my best shot.
oh'mike 08-23-2012 08:41 PM
You will do fine--keep the sponge wrung almost dry---lift and roll the sponge as you wipe---much like you would if wiping up spilled jelly on the floor----Good luck and have fun.
sixeightten 08-23-2012 08:51 PM
You may need to install a shoe molding. It is common practice on tile floors. This will hide about 1/2" and will also eliminate any gaps between the base and the floor.
Sycamore Inn 08-24-2012 10:45 AM
That shoe molding is a nice finished look. Maybe someday but right now that would require too much labor because all of the baseboards would have to be done. Thanks for the suggestion :)
JazMan 08-24-2012 01:55 PM
I don't understand why you think the carpenter messed up if there's a gap between the tile you installed and the base molding he installed. The tile is not close enough to the wall if it was planned to not also install shoe molding. (which is normal with any hard floor covering).
Jaz
firehawkmph 08-24-2012 09:13 PM
You could also fill the grout voids with a cake decorator type of bag. Sold at tile supply houses. It would save a lot of mess and allow you to put a little dab of grout just where you need it. Also, how bout posting a few pics so we can see what you're dealing with.
Mike Hawkins:)
