Grouting Rough Slate Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 08:50 PM   #1
grouting rough slate tiles
I'm about to grout my kitchen.
Any tips on how to get all of the grout out of those ridges on rough slate tiles?
I tried a grout bag my last project and it wouldn't flow for me so I threw it away and went back to the old "smear and spread" method. I find that I can't get it as clean as I want it. Those ridges just collect the grout and are impossible to clean !!!! Does grout release even work for this problem?
the carpenter is offline   Reply With Quote
Old 11-16-2010, 09:14 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sealer will help. All stone tile should be sealed first anyway.
Grout release will also help.
When grouting go slow and use a toothbrush as you clean up. I have never had a slate floor I couldn't get clean.
A grout bag has a slight learning-curve but it is easy. The grout must be a mixed slightly thinner than usual to keep it from coagulating in the narrows of the bag too soon.
Using a good (new) grout float is a key factor also. Try the gummed-rubber grout float.
XXX
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
Removing cured grout from surface of slate tiles Mikedks Flooring 5 09-28-2009 12:38 PM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 04:00 PM
Slate tiles on floor and walls Mr Chips Flooring 8 04-09-2008 06:49 PM
