Grouting Over Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:21 PM   #1
Rewards Points: 97
Grouting over Grout
My friend had a contractor renovate his whole bathroom. After it was done there was about a 2 ft square spot where the grout has sunken in a lot. He doesn't know how it happened or when it happened after it was finished. I know your not suppose to grout over old grout. Is there any way to fix this with out ripping all the grout in the whole bathroom and re-grout the whole thing? The contractor was a complete hack after looking over his work
Tyus4 is offline   Reply With Quote
Old 12-21-2011, 09:56 PM   #2
Rewards Points: 558
You can remove the grout from that section only and re-apply new matching grout.
epson is offline   Reply With Quote
Old 12-21-2011, 10:00 PM   #3
Rewards Points: 97
after removing grout and applying the new stuff, what about the bonding of the new/old grout on the edges where its removed and not removed? Too small of a spot to worry about?
Old 12-21-2011, 10:11 PM   #4
Rewards Points: 558
Standard tiles are unfinished on the edges and arenít made to be left exposed. One solution thatís easy and attractive is edge tiles. Also called border tiles or bull nose, they are rounded and finished along one edge, so you can install them next to the tiled area and give it a finished look.
Old 12-21-2011, 11:27 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
epson: "Standard tiles are unfinished on the edges and arenít made to be left exposed. One solution thatís easy and attractive is edge tiles. Also called border tiles or bull nose, they are rounded and finished along one edge, so you can install them next to the tiled area and give it a finished look."
Who said anything about that in this thread?
Yes, exactly, don't sweat the small stuff.
XXX
Grouting over just sealed new grout junkgirl Tiling, ceramics, marble 2 04-05-2011 06:18 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
Caluking instead of grouting tile in shower? KansasWind Flooring 5 03-30-2008 11:43 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
