Grout Width Around Shower Drain? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 09:48 AM   #1
Grout Width around Shower Drain?
I am laying tile on a shower drain using a sheet of 2x2 stone tile. After much trial and error I believe I have done an okay job of getting the tile cut to fit a round drain. Photo is attached.
What I am concerned about is whether I have cut too tight to the drain. Is there any guidance for what width of a grout line should be left around the actual drain? Is it okay to take the tile up tight to the drain or better to have a bit more of a grout line.
Any other general gotchas to look out for when tiling around the drain are much appreciated.
dekohl is offline   Reply With Quote
Old 07-03-2012, 10:21 AM   #2
Renovations contractor
Bonzai's Avatar
A square drain grate would have made life a lot easier for yourself as they are designed for 2x2 tile so no cutting around the drain is needed.
Use a colour matched grout caulking such as by Mapei for around the grate ... Always use a silicon product such as this when going from tile to a different material such as the metal grate.
In terms of width ... 1/16" to 1/8" is best for that tile size.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
Shower grout and puffy wall sierra1194 Tiling, ceramics, marble 5 09-13-2011 02:23 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
