Grout Sealants - Flooring - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 10:10 AM   #1
Grout sealants
Hi all. Newbie dumb question:
I'm trying to seal grout lines between glazed tile and the procedure is going well.
However, in testing I find water still soaks in after the recommended 2 coats.
The sealant I'm using is the Dupont water based found at Lowes.
The question: Is there a better sealant available that is truly a sealant and will not allow penetration? Also, if there is........how difficult to use?
Thanks, much.
stormwatch89 is offline   Reply With Quote
Old 08-21-2012, 12:29 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Post some pics of your grout lines, water is not suppose to soak in the grout sealed or none sealed and sealing grout doesn't make grout water proof grout is already meant to reject water once the grout drys.
Is this sanded or none sanded grout and is the sealer for which ever type you have?
JetSwet is offline   Reply With Quote
Old 08-21-2012, 08:44 PM   #3
Thanks, Jet!
First, you give me far too much credit. I've just moved in here and to find my camera would be amazing.
The penetration I'm seeing is almond grout (sealed) and darkening by pouring a small amount of water on it.
As far as sanded or unsanded: I have no clue. It's a resale home of approximately 10 years and it is what it is.
Thank you so much for trying to help. I'm sorry I don't have better info.
Any other ideas you might have would be so much appreciated!
Storm
Old 08-21-2012, 11:45 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 218
Storm,
Grout sealer is not meant to completely 'seal' moisture from wetting the grout. If sealer did that, it would peel off like oil-based paint on an old un-cared for house. Sealer slows the intrusion giving you a little time to wipe the spill. Apply a couple coats or so until no more soaks in. Be sure to wipe off excess from the tiles before it dries.
Jaz
Old 08-22-2012, 05:39 PM   #5
That makes sense! I guess I was looking for a way to avoid cleaning.
Thanks!
Old 08-22-2012, 07:04 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 218
Honey, is that you?
Jaz
Old 08-22-2012, 07:08 PM   #7
Shucks
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 07:31 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
Polyblend 'Grout Renew' - any experiences? spidrw Tiling, ceramics, marble 0 04-22-2010 01:37 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
