Grout Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 05:59 PM   #1
grout problem
did at least a dozen baths, never saw this before. 30 square ft of 12x12 ceramic. used polyblend sanded, tan color. finished 30 hours ago and the grout looks ok, except color is white.mixed well with drill, not too wet, didnt work with too much of a wet sponge(did plenty of previous jobs with same technique). odd part is the picture shows white grout lines and the clump of grout in pic i fished out of garbage is perfect match. called company and tech mentioned efflorescense, and suggested let grout cure for a week and scrub with sulfamic acid. if i have to remove it id rather do now instead of letting grout cure for an extra week.if i wet it with rag the grout darkens to a good match.
mazey is offline   Reply With Quote
Old 03-23-2012, 06:04 PM   #2
additionally i just spoke with neighbor, he had same problem with his backsplash, final grout color looked white instead of a dark tan. the phone tech mentioned maybe the local water supply affected it? he mentioned distilled water in future , any ideas?i hate to waste e week to find out the acid wash didnt work
Old 03-23-2012, 07:14 PM   #3
anybody have similiar problem? neighbor just saw it and he thought it was white grout, its that uniform in color. until i showed him sample of the correct tan color.
Old 03-23-2012, 07:36 PM   #4
DIY staff
Rewards Points: 7,174
Only time I've seen that ,to much water was used in the cleaning process.
However, the grout usually looks blotchy --not consistently light.
Jaz might have an idea,sorry I don't.
Old 03-23-2012, 07:51 PM   #5
thats weird part, not blotchy at all, it appears to be "white grout"
Old 03-24-2012, 06:49 AM   #6
DIY staff
I just don't know---Have you tried sanding a small spot?
See if it's just the top ? I see the scrap sample is the correct color---might be your washing method--
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
another grout color change question tryinitmyself Flooring 1 02-22-2008 07:50 PM
sanding grout C99 Flooring 4 02-18-2008 06:10 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
