Old 10-20-2009, 06:45 PM   #1
Post Grout peeling out from shower floor tiles. What's the problem?
Hi,
I recently build a new house. The shower has a water-proof base on a concrete foundation. The tiles are on the water-proof base.
My problem is that the grouts peels off from the tiles when I shower.
Got my builder to look at the problem. They claim that the issue is a grout problem. They got their tiler to come in and re-grout the tiles. After allow the grout to dry, I took a shower and the grout began to peel off gain.
Can anyone advice on where the problem is?
Is there an issue with the tiling?
hellstorm is offline   Reply With Quote
Old 10-20-2009, 09:07 PM   #2
Tileman-Manufacturers rep
Can you describe this waterproof base you're talking about? All showers require a waterproof membrane of one type or another. Do you know how the shower was built and with what materials, step by step?
Grout is between the tiles not on them, so how is it peel off them? If the grout comes out of the joints or is powdery, there must be movement in the floor. Are the tiles loose? Tap them with the handle of a screwdriver to listen for a dud sound. Did they use new grout the second time?
Got pictures?
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 10-21-2009, 12:25 PM   #3
You should seal the grout in a wet area like a shower floor.
sdsester is offline   Reply With Quote
Old 10-21-2009, 04:21 PM   #4
Yes you should seal the all grout regardless if it's a wet or dry installation. But what does that have to do with the grout coming out?
Jaz
Old 10-21-2009, 04:40 PM   #5
Answer post #2.
R&D Tile is offline   Reply With Quote
Old 10-21-2009, 10:59 PM   #6
Not very sure what type of base is it. It's like a big square bin cover, sloping down into the middle. What they did was that they laid the base on the concrete foundation and tiled on top of base.
Tapped on the tiles as suggested by Jazman. Sounds a bit hollow at the sides. Also I can feel the vibrations around the tiles ever though I tapped very lightly. Attached is a picture. Similar issues across the whole base.
They use new grout for both times. And since it's for the shower, I would assume the builder would have sealed the grout.
Old 10-21-2009, 11:15 PM   #7
I'm pretty positive, (and you confirmed), the tiles are just sitting there being held in place by gravity. You need to remove all the tiles and possibly the entire base and up the wall a few rows or the entire thing.
Did they slope the floor with wood and cement backer board? Do those cut lines start at the four corners and go to the drain?
Can you post more pics or email them to me?
Jaz
More On This Topic
Hi this is Jon and in this clip we'll be grouting. If we take a look at the base of our door on the inside we have a nicely laid tile that's grouted, however when we did install the door we had to chip away some of the grout so that our new door would... Read More »
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
Today we’re going to be re-grouting the tile around the window in the bathtub. Once your grout has set out for about five to eight minutes, you get yourself a grout trowel, which is just spongy so you can apply the grout. And you just scoop some... Read More »
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
How to Prep Mosaic Surfaces
How to Prep Mosaic Surfaces by Expert Village
To prepare our wooden base before we start, you'll want to rough it up a little. It helps the tiles adhere to the surface. So, I have here something that I made. I just put nails into a board until they stick out. This is great for really gouging up a... Read More »
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 02:39 PM
shower problem rebelbull Plumbing 3 07-25-2009 10:30 PM
shock in shower tbwoods Electrical 64 07-23-2009 01:26 PM
Caluking instead of grouting tile in shower? KansasWind Flooring 5 03-31-2008 12:43 AM
grout problem farrington135 Building & Construction 3 10-17-2005 07:30 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
