Grout Keeps Coming Up - Flooring - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 08:55 PM   #1
Grout keeps coming up
Hi guys. Grout keeps coming up and cracking in bathroom. I suspect the floor under the tile moves a bit due to building vibrations. Is there some kind of caulk/grout that can go in and replace the chipping? Thanks in advance.
MikePet is offline   Reply With Quote
Old 12-19-2011, 09:02 PM   #2
DIY staff
Rewards Points: 7,174
I think you are describing a tile failure---sorry but I believe the floor needs to be redone.
There is no grout that will hold up to tiles moving--and a flexible caulk will look like the Dickens in no time.
Old 12-19-2011, 09:40 PM   #3
So I'd have to take up the entire bathroom floor just to fix the 2 tiles that are always chipping?
Old 12-20-2011, 07:11 AM   #4
DIY staff
You didn't mention that there were only two tiles and the rest of the installation was fine.
In that case--remove the two tiles--Find and fix the problem and install new tiles---then grout.
ben's plumbing (12-20-2011)
Decided to remove grout and re-do PatrickGSR94 Tiling, ceramics, marble 7 11-25-2016 08:38 PM
Grout color rubs off lmlark Flooring 12 07-17-2013 07:55 PM
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 09:45 AM
Grout Discolouration Beth P Tiling, ceramics, marble 9 10-27-2011 09:22 PM
Grouting over just sealed new grout junkgirl Tiling, ceramics, marble 2 04-05-2011 06:18 PM
