Grout Dried On Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 08:27 AM   #1
Grout dried on tile
I just tiled the bathroom floor and there are still areas where I can see the dried grout on the tile. I wiped the floor several times after tiling and have tiled before and not had that problem. I even used a sponge with rough side and scrubed and even with a cotton towel. Anyway, is there a way to get it off the tile without damaging it? someone has to have a miracle solution. Thanks,
H.O.P. is offline   Reply With Quote
Old 05-20-2011, 10:56 AM   #2
I had success with a haze remover from Lowes and scrubbing like hell. Hope that helps, but also hope someone knows an easier way.
Happybg81 is offline   Reply With Quote
Old 05-20-2011, 11:51 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
This is not an uncommon question. If you look at the solid dark bar above your post, you will see a tab for "search". Enter in "remove grout haze" or some such and you should find them.
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 07:31 AM
Grout Color for TIle bwad General DIY Discussions 8 09-16-2010 01:20 PM
Vinyl self stick tile grout cesuark Flooring 3 09-06-2010 04:13 PM
Remove tile grout ninghai Flooring 6 06-06-2010 10:51 PM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 10:51 PM
