Old 12-05-2012, 01:46 PM   #1
Is "Grout Boost" any good????
Hello All,
As the thread says, is Grout Boost any good or worth using? Please respond with personal and definitive opinions/experience.
1) Even if it only partially helps to block stains it would seem worth it for an exterior tiled patio (as I'm in the process of finishing). Are there other qualities to it that should also be considered?
2) Does it make the grout install more difficult and what about cleanup?
3) Does it slow the curing process of the grout?
Thanks,
Ralph
Ralph III is offline   Reply With Quote
NJ Lumber Yards - good suppliers for decking? Quicksmoke Building & Construction 5 03-23-2012 02:50 PM
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 09:26 PM
Where can I find good contractor and building material suppliers? geordge Green Home Improvement 3 03-11-2009 12:11 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
