Grout Application...Need An Alternative Method - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 05:22 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'll be applying two coats of a high-end penetrating sealer to the tiles, and hopefully that will help keep everything looking good. One coat will go on the surface before grouting, and the second coat will be after grouting.
Unfortunately that isn't going to help for long. I've seen it way too many times. There is nothing you can do to stop the leaching of the iron. I installed a big slate patio, finished it just last fall and yesterday I went to take a look at it. Very disappointing!!! That sucker had five or more coats of sealer both before and after grouting and it still looks like hell already.
OH WELL!!! They were warned.
I also have a DIY doctor that did his own slate shower and then later called me to try and stop the leaching. We cleaned and then sealed that sucker over and over and cleaned the stained tub. Now the stains are reappearing and the leaching has begun again.
Old 06-24-2008, 05:39 PM   #17
Registered User
Termite's Avatar
Very encouraging! I'll just have to keep it as clean as possible and hope for the best!
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
sanding grout C99 Flooring 4 02-18-2008 05:10 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
