#16 |
Moderator
"Green" hardwood flooring underlayment and moisture barrier question
People, animals and cooking give off moisture in a house. Add the water sources like clothes washing, bathrooms (toilet with the lid up- always cover your toothbrush) hand washing, clothes dryer, etc., you get some water vapor that has to go somewhere. The pressure differences (natural and forced) in a house feed the "stack effect" which forces moisture right through holes (light fixtures, outlets, switches) in drywall on the ceiling into wall/joist spaces, through the subfloor- to your new flooring- if the pressure drive is strong enough, humidity inside high enough, etc. http://www.wag-aic.org/1999/WAG_99_baker.pdf
Air changes and where the "make-up" air comes from: http://www.buildingscience.com/docum...rent-this-time Notice the arrows to the floors: http://www.conservationtechnology.co...eakagePathways Flooring manufacturers want to warranty their products and know that inside/outside (think wet) air will get to the undersides, sooner or later. Check any house for the RH and watch it change with number of occupants/seasons/weather- rainfall, temperature, % of moisture in the air, etc. http://philipmarshall.net/pdf/tsongas_92_residences.pdf Painted drywall is a good air-barrier. Another stack effect article: http://www.buildingscience.com/docum...control_ed.pdf Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#17 |
Thank you, Gary. I see your point. However, it's all not compelling enough for us to want to put an asphalt product into our bedroom. I also called another respectable flooring company in our town, and they emphatically said we don't need a vapor retarder in our particular situation. Plus, the installation instructions for our bamboo don't call for any underlayment for nail-down installation. So there seem to be a lot of diverging opinions rather than a unanimously accepted directive, and we feel we can take the risk and just use red rosin paper.
| Display Modes | |
| Laminate Floor Underlayment Question | hurt138 | Flooring | 4 | 11-08-2011 01:30 PM |
| Another thread about subflooring & underlayment choices for a first timer DIY tiler | pmergler | Flooring | 8 | 07-11-2010 03:00 AM |
| how important is it for moisture barrier to cover sides of floating floor? | conradA | Flooring | 2 | 04-29-2010 11:13 AM |
| Basement flooring question | kelot | Flooring | 2 | 10-23-2008 05:06 PM |
| Quality Underlayment combinations for engineered Hardwood? | tigerbalm2424 | Flooring | 5 | 07-25-2008 07:04 PM |
