Old 09-27-2007, 01:43 AM   #1
Granite tile counter question
I have a small bar area at my house where I recently decided to put granite tiles on the counter. Theorizing that since it was a counter and not a floor, I did not use Hardibacker or a similar product. The counter surface I adhered the tiles to was a solid wood at 3/4 of an inch (but a better grade than plywood). The guy at the big box store suggested I use a pre-mix product made for stone. It resembled the kind of adhesive you would use for vinyl flooring or outdoor carpet. I got the tiles on there nice and level, let it set for 48 hours, then grouted. About a week later cracks began to appear in the grout lines and the tiles appear to have "heaved." Any ideas what went wrong or if it can be fixed? The counter is 17 inches wide and I put 12 inch tiles on it.
ryguy is offline   Reply With Quote
Old 09-27-2007, 10:13 AM   #2
I'd guess that the 3/4" plywood is too flexible. How is it supported? Does it have a frame under it?
NateHanson is offline   Reply With Quote
Old 09-27-2007, 12:06 PM   #3
Looks like your wood absorbed moisture from the thinset and swelled up. I did some tile research recently, and not a single place recommended gluing tiles to wood. They all say use at least a 1/4" backer, mortared, screwed, taped and patched.
scorrpio is offline   Reply With Quote
Old 09-27-2007, 12:31 PM   #4
He didn't use thinset. He used a tile adhesive, like mastic. (ALWAYS use thinset! )
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
Granite Tile ....on wall ? mahjohn Building & Construction 7 03-01-2006 08:55 PM
